Bricks In Rim Joists - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-17-2014, 09:15 PM   #1
bricks in rim joists
I'm trying to rewire part of my house and need access to receptacles on the first floor from the basement. Unfortunately, the space between my foundation wall and subfloor is filled with brick and mortar. It's 100+ year old house and balloon construction. There are one or two spots where the bricks are knocked out and I do see a rim host. Can anyone tell me if it's OK to knock some of the brick out in order to fish wire? Also, what's the purpose of this brick?!!
OneRestlessDude is offline   Reply With Quote
Old 08-20-2014, 12:53 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
If the wall studs drop all the way to the mud sill, then the bricks were most likely installed as a fire stop, to keep flames from travelling up into the stud cavities. If I were going to knock them out, I would put something back in to serve the same purpose.
Old 08-28-2014, 08:30 AM   #3
Rewards Points: 960
Little late, but the bricks may be the foundation, so the joists were let in to the brick foundation? It really needs to be look at more carefully before you remove them.
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
concretemasonry (08-28-2014)
Tags
brick , rim joist , wiring
Sister joists or to add joists in between... dftc Building & Construction 32 02-26-2014 09:54 PM
Replacing too-short joists after mud bed removal dgfit Building & Construction 5 01-02-2014 10:15 PM
Updating Timber & Balloon Framed Home (LONG POST) Pittsville Building & Construction 13 05-29-2013 12:15 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Strengthening Joists Before Basement Finish braverichard Building & Construction 16 06-20-2010 07:28 PM
