Brick Walls - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-31-2013, 04:12 PM   #1
Rewards Points: 20
Brick walls
Remodeling a old bathroom. There is some old ugly panel on the walls with brick behind it. I want to gut it out and replace it with drywall, but can't figure out the best way to attach the drywall. Is there some way I can attach it to the brick itself or do I have yo frame it out.
Delvia Carter is offline   Reply With Quote
Old 10-31-2013, 04:25 PM   #2
Rewards Points: 14,306
Best way is to frame it out, brick will be a pain to attach anything to it and get it all flat.
Delvia Carter (10-31-2013)
Old 10-31-2013, 04:29 PM   #3
K&B Designer
Live_Oak's Avatar
Is it actually a true solid brick wall , or just a brick veneer with studs behind it? Why function did the brick have? Part of an old masonry chimney, or something decorative?
If it's solid, like a chimney, it's best to fir it out as Joe says. If it's a brick veneer, get dusty and chisel that thing out!
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Rotting Door Jamb - Basement Walls Made of Hollow Clay Brick pilk00 Concrete, Stone & Masonry 12 05-05-2013 08:09 PM
brick veneer with SIP walls tap210 Building & Construction 0 06-14-2011 11:20 AM
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 06:09 PM
Deteriorating brick walls jelost Building & Construction 2 03-15-2009 08:21 PM
Old Brick House inside walls rick32 Building & Construction 6 11-08-2007 06:49 PM
