#1 |
Brick veneer
I'm cutting some old brick for a back splash in the kitchen. I'm not sure what would be the best sealer for it. It wont be above the stove but will be above the sink and rest of the cabinets. Also what width would you suggest to cut the brick?
#2 |
Stay-at-home GC
Brick veneer
The thickness of your cut will have a lot to do with the quality of the brick. A good brick can be sawn lengthwise (ripped) much thinner than a lousy brick.
The vibration from the saw blade will break cheaper bricks down. The thinner you go, the less mortar you'll have to use to "grout" between
Can correctly identify Shinola 3 out of 5 times* *Under ideal conditions Some days, my Life needs a Rewind/Erase Button. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Display Modes | |
| Fireplace Brick Veneer TV Mounting | RICKM15752 | Building & Construction | 3 | 12-14-2010 05:03 PM |
| Question Re. Parging Over Brick | Captain.Sassy | Building & Construction | 19 | 06-22-2010 09:50 AM |
| Replacing band joist behind brick veneer | jzambon | Building & Construction | 0 | 03-09-2010 12:58 PM |
| New opening in a brick veneer wall - installing new brick ties? | GrantJohnson | Building & Construction | 3 | 01-28-2009 11:17 AM |
| Brick Veneer on steel angle iron | sandyman720 | Building & Construction | 3 | 07-09-2007 09:21 PM |
