Brazilian Walnut - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-27-2014, 12:23 AM   #1
n2omichael's Avatar
Rewards Points: 115
Brazilian Walnut
Hey Guys
Has anyone here used Brazilian Walnut for hardwood flooring? I love the look of it, and I'm told it's almost indestructable. However, I have heard it's a total pain in the butt to work with, any input appreciated!
Michael
n2omichael is offline   Reply With Quote
Old 01-27-2014, 07:12 PM   #2
Stairguy
Millertyme's Avatar
Rewards Points: 508
Aka Ipe. It's very hard stuff. One of the hardest on the Janka scale. I believe it needs to be predrilled and nailed or screwed by hand, I'm not positive though.
Millertyme is offline   Reply With Quote
Old 01-27-2014, 07:24 PM   #3
recently retired
Rewards Points: 280
I did a continuous Ipe 3 flight handrail once, never again. It is unbelievably hard to work with and very hard on tools.
Keith Mathewson is offline   Reply With Quote
Old 01-27-2014, 07:26 PM   #4
Stairguy
Millertyme's Avatar
Rewards Points: 508
Keith, what did you use to glue it? I tried west systems, gorrila glue and titebond 1. None seemed to work. I didn't try titebond 3 though
Old 01-27-2014, 07:29 PM   #5
n2omichael's Avatar
Rewards Points: 115
What would you guys recommend as a compromise? I want something durable, and nice.i really like the "tigerwood" as well, but, it's hard to find
Old 01-27-2014, 07:30 PM   #6
Stairguy
Millertyme's Avatar
Rewards Points: 508
Brazilian cherry
The Following User Says Thank You to Millertyme For This Useful Post:
n2omichael (01-27-2014)
Old 01-27-2014, 07:43 PM   #7
recently retired
Rewards Points: 280
Millertyme,
It was a cap on a metal rail. I used gorilla glue and dominos but I think the real holding power was the screws every few inches through the metal rail. It was one of those jobs where you wanted out after the first day. In the end the customer loved it- me not so much.
Old 01-27-2014, 08:13 PM   #8
Civil Engineer
Rewards Points: 4,854
I built a deck out of ipe. Had to predrill everything, but that was not a real problem. Carbide saw cut it very nicely. It all worked out fine. Could not glue it however, even with very expensive epoxy glue.
Old 01-27-2014, 08:15 PM   #9
n2omichael's Avatar
Rewards Points: 115
I need it for a small living room in front of my gas fireplace at my cottage, around 200 sq.ft.
Old 01-27-2014, 08:34 PM   #10
Stairguy
Millertyme's Avatar
Rewards Points: 508
As long as you don't have to mill or glue it. Its just the extra time fastening it. But only 200 feet go with what you like and have no regrets. Just keep in mind although the wood is durable sometimes the finish isn't. So scratches will still show in the finish.
Old 01-27-2014, 08:38 PM   #11
n2omichael's Avatar
Rewards Points: 115
Sounds good
It will see considerable foot traffic (and weather changes when I am not there in the winter) so, something hard and durable is a must. I don't mind if it's a bit of a pain to install since it's a small space and I will be only be doing once, hopefully!
Old 01-27-2014, 08:40 PM   #12
I used cumaru, another of the Brazilian hardwoods. Otherwise known as Brazilian teak. I love it, and it was easy to install, not much different than any other hardwood flooring. It was pre-finished and has worn extremely well. It ranks right behind the Brazilian walnut on the Janka scale. I also used Jatoba, which was unfinished and raw, and it was ok to work with.
northernlite is offline   Reply With Quote
Old 01-27-2014, 08:44 PM   #13
n2omichael's Avatar
Rewards Points: 115
Thanks Northern!
I will look into that, sounds like another potential option!
Old 01-28-2014, 05:39 AM   #14
DIY staff
Rewards Points: 7,174
Mesquite is a handsome floor----and also hard and water tolerant.--Just a thought---it's not popular so finding a source might be difficult.
3/4" Brazilian Walnut solid Hardwood. scrubce Flooring 2 05-23-2011 12:25 AM
Walnut countertops Master Brian Carpentry 26 11-13-2010 10:38 AM
Advice needed on installation of BELLAWOOD 5/16" x 2-1/4" Select Brazilian Walnut lifterpuller Flooring 2 05-30-2010 01:30 AM
Brazilian Walnut Plank Stability JDeFuria Flooring 3 03-13-2009 05:38 PM
Brazilian Walnut (Ipe) Prefinished Flooring dcd22 Flooring 3 10-19-2007 08:22 AM
