Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-02-2011, 10:23 PM   #1
Brand New Maple Cabinets...Stain?
I am new to woodworking/cabinetry but am doing pretty well. I have built speaker boxes for years and have great tools but actually doing custom cabinets is much different.
My question is I have just re-done my entire kitchen with Maple hardwood fronts and Import Maple Plywood sides/shelves. I want to stain the cabinets dark like the (Minwax Bombay Mohagany Color).
My questions are is what do I need to know and what do I need to do to achieve this?
Any input appreciated!
thanks
cbrdolby is offline   Reply With Quote
Old 02-03-2011, 07:30 AM   #2
If the wood is prefinished, or finished, you can't stain them. And veneers are usually too thin to strip and sand down fot staining. Minwax makes a product called Polyshades, poly with stain mixed in. I have never had satisfactory results from it, but you could try it on some scrap pieces. It tends to pool and the pooled areas are darker.
Old 02-03-2011, 09:22 AM   #3
You might want to re-post this in the painting section of this web site for a better response...........................not that just bills response was bad. Just the fact the you will get more responses.
mark942 is offline   Reply With Quote
Old 02-03-2011, 11:35 AM   #4
thanks ill try that
Old 02-03-2011, 12:29 PM   #5
thanks
Maple is a wood that needs to be conditioned prior to putting the stain on or it will blotch up. I used Minwax,"Merlot" water stain on my maple cabinets. Water stain I found to be a little harder to work with then the oil stains. Once I used a Fuji sprayer on them, it was so much easier then a rag or brush.
Ron
Old 02-03-2011, 02:08 PM   #6
rditz's Avatar
I had built my cabinets for a pantry and recently built a bookshelf/storage unit for under stairs. It was made from maple veneer plywood and trimmed in solid oak. I simply brushed on Minwax (Cherry), 1 coat. let dry. then 2-3 coats of Minwax Polyurethane (sanding lightly between coats).. if i wanted it darker, I would have applied a second coat of stain. everyone that has seen these have been very impressed.
I think the suggestion of trying on a piece of scrap/cut-off will show you what you will get.
good luck
rod
rditz is offline   Reply With Quote
Old 02-03-2011, 05:13 PM   #7
Moderator
Termite's Avatar
Stain contains solid pigments and dense woods like maple don't take it easily or consistently.
I'd really suggest a dye as opposed to a stain. Dye can be put into alcohol and applied...The alcohol evaporates and the liquid-based color is left. You can also use water but I'd go with alcohol. It works awesome, is cheap and easy, and it will look a heck of a lot better than stain. TransTint is the dye I usually use.
Old 02-04-2011, 01:09 PM   #8
Practice on scraps of both maple ply and solid maple as the absorbtion rate will vary.
Ron
Old 02-04-2011, 01:25 PM   #9
Well, this will probably curl a few eye brows, and would certainly require some practice and planning in order to maintain consistancy through a complete set of cabinets, but as long as you are experimenting, and want to go dark, with maple I would also try a torch. It can create a very unique look.
DexterII is online now   Reply With Quote
Old 02-04-2011, 02:08 PM   #10
The phrase would be, "singe a few eyebrows".
Ron
Old 02-04-2011, 02:30 PM   #11
Ron
Soooo... maybe that's what happened to the ol' boy I used to watch do this!
Problem - Polyurethane bleaches out Stain Color on Maple Table GhanaBhuti Painting 9 09-05-2011 11:50 AM
Restaining maple cabinets cheller Kitchen & Bath Remodeling 0 09-01-2010 01:25 PM
painting new custom maple cabinets Paulettediaz Painting 5 07-12-2010 07:45 PM
Do I need to stain cabinets? bluefitness Remodeling 5 12-24-2008 10:46 AM
I need help with kitchen cabinets trying to take off stain swishersweet7 General Discussion 2 03-30-2008 01:25 PM
