Is A Brad Nailer Good Enough For Trim - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-31-2011, 09:32 AM   #16
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
predrilling and hand nailing has very little hold power. gun nailing doesnt always need to be scraped... if this is the situation you have your drive pin on your gun is geting worn and needs to either be filed down or replaced. ive only had this problem when using cheap nailers or old porter cables, i currently own one paslode and 2 bosch 18 gauge guns none of them cause that problem
woodworkbykirk is offline   Reply With Quote
Old 12-31-2011, 02:54 PM   #17
Retired carpenter
Thanks, Kirk, you nailed it: mine is an old Porter Cable.
abracaboom is offline   Reply With Quote
Old 12-31-2011, 06:33 PM   #18
A Brad Nailer is good for hanging your baseboards.
TurboDIYer is offline   Reply With Quote
Old 01-01-2012, 11:17 PM   #19
Be sure you hit a stud if you use 18g nails on base. The only trouble might be if your base doesn't lay tight between two studs your nails won't be long enough or strong enough to catch the plate. You could probably rent a 15g angle finish nailer pretty cheap at your local rental place.
rodthebod is offline   Reply With Quote
Old 01-02-2012, 06:08 AM   #20
Crusty Old Dude
Big Stud's Avatar
You really should have a larger nail as has been mentioned on base, crown, chair rail, and the outside of casing. If you can not afford a finish nailer, the cheaper way to go is to hand drive as has also been mentioned,
All the best to you and yours, Tom
Big Stud is offline   Reply With Quote
jammed bostitch brad nailer philS Tools 7 02-03-2012 07:33 PM
Senco Cordless brad Nailer not firing flrmdn Tools 0 10-10-2010 05:19 PM
Porter-Cable nail gun kit any good? ajtool Tools 17 08-15-2010 08:56 AM
Can I use a framing nailer as a roofing nailer? capslock Tools 1 06-10-2010 11:41 AM
Do I need a Brad or Finish Nailer? atm Carpentry 13 03-10-2010 10:43 PM
