Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-13-2010, 08:28 AM   #1
Question
boxing in HVAC ducting
I need to box in my HVAC ducting but the span including the main house beam is over 5ft. can I use 2x3 studs to hold up the dry wall laying them flat? or do I need to stand them up, Or should I go to a 2x4 that is standing up?
donait is offline   Reply With Quote
Old 08-13-2010, 08:58 AM   #2
Not so new
12penny's Avatar
I normally do mine with steel studs and hat track (sometimes called hat channel).
Stud out the vertical "sides" with steel studs, and then use hat track (the profile reminds you of a hat) to connect the 2. Its a ridgid assembly and wont bow, warp or twist.
Goggle hat track. Should be available wherever steel studs are sold.
12penny is offline   Reply With Quote
Old 08-14-2010, 06:04 PM   #3
Not so new
12penny's Avatar
hello?....I guess I didnt answer yur question. Of the choices you provided I guess I'd go with 2x3 uprite.
Dont forget the permit and a means of egress.
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 08:28 AM
HVAC ducting and foam insulation seadrift HVAC 1 08-17-2009 01:11 PM
Installing Ducting for New Home Addition marshstate HVAC 12 07-19-2009 10:23 PM
Engineered Joists & holes for HVAC ducts walt1122 Building & Construction 3 07-04-2009 08:37 PM
Do I need a HVAC return vent in basement? westing HVAC 12 01-28-2009 01:09 PM
