Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-15-2009, 05:13 PM   #1
Extreme DIY Homeowner
Scuba_Dave's Avatar
Default Box/Bay window header
Well I'm preparing to redo the last windows in the house
Currently a bay window
This will have (1) window at an angle towards the left (front of house)
Then the "wall" will run straight back to the new garage
There will be 2 windows in the straight part
Curently I have a TW3046-2 mulled set of windows I'm planning on using
They are 75 1/4" wide by approx ~57 high
Header already exists in bay window opening
There will be cantilevered floor joists below as additional support below
So there will be a floor now in front of the windows instead of a shelf
Floor joists will come out about 22" - currently the amount the bay sticks out
2x10 Floor joists will go back in along existing floor joists for ~4'
I need a header over the windows to carry the small roof load only
Usually I just use (2) 2x10's or 2x12's for windows on an interior wall
This is the gable end of the house
I doubt that there is more then 2x4's in there right now
Will 2x4's work.....2x6's?
Not sure how to size this........
The header will span the mulled windows (75") then continue on another 17" & be securely attached (hanger) to the new garage wall
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Old 08-15-2009, 08:59 PM   #2
We pick these?
I like to use 2x10 with 2x4 across the bottom. The smallest I ever use are 2x6, even if 2x4 is allowed. I think the bulk of the load is carried by the floor joists followed by what's transferred to the main wall through the rafters/ceiling joists and the through the header/hanger connection. A nicely fastened shearpanel would further strengthen it up transferring more of the weight to the garage wall. My mother-in-law wants me to build one of those onto her house...
NailedIt is offline   Reply With Quote
Old 08-15-2009, 09:06 PM   #3
If you are using hem/fir - f.b.=1150. a 3x4 (2-2x4) will carry 488# over an 8' span. You are carrying 1' house roof + 1' overhang + 1' ceiling joist = 40# per ft. x 8' = 320# 488-320= 168# under the limit of total load. Not taking any snow load into consideration.
Be safe, G
GBR in WA is offline   Reply With Quote
Old 08-15-2009, 09:19 PM   #4
Scuba_Dave's Avatar
Thanks for the info
I'll go with (2) 2x6's at a min
I had thought of using the hardi-plank cement board under the windows
But I may fancy it up & trim it out & use white stain
Or I may use rounded shingles to match the front peak
Another ask the wife her opinion decision
Trimmed out like panels ?
Old 08-15-2009, 10:38 PM   #5
We pick these?
Load transfer paths are affected by points of connection.
Nice panels, but those are aluminum or vinyl, eh? I'm looking at some raised panel molded drywall to use indoors. I wonder if there is a similar fiber-cement product available for exterior?
Old 08-15-2009, 10:54 PM   #6
Scuba_Dave's Avatar
Yeah that looks like alum panels
I was thinking of replicating it in wood
They do have smooth fibre board - not sure on sizes
Old 08-26-2009, 11:18 PM   #7
Scuba_Dave's Avatar
Well, back to the drawing board sort of
MIL looked at the windows I have & thinks they are too big
I have the same windows in the sunroom...BUT 9' ceiling out there
So the windows are up higher
Showed the wife how low they would be & she agrees
So we are going with 2 venting side windows flanking a picture window
It will match the (3) front windows, fractional grid on picture window
Hmmm...only good pic of front windows is from Halloween
More On This Topic
What people like to do is to freshen their house up. They like to open their windows. Now if you have severe allergies like I do to environmental things such as trees, grasses, pollens, now that the spring is coming, seems like a great idea to air out... Read More »
Victorian architecture became popular during the reign of England's Queen Victoria in the late 1800s to the early 1900s, but the period of Victorian architecture spans from 1825 to 1900. The most popular of these houses was the Queen Anne. Queen Anne... Read More »
Rod McMahon for Expert Village generally uses for a sawzall is demolition or you could use it for cutting floors, you could get pretty precise once you have gotten use to it. Develop a little skill with it. As rough as it looks you could actually do some... Read More »
If you are at a loss as to what to do with your keepsakes, handed down furniture, year books, children’s toys or holiday ornaments, you should look up and consider your attic. Homes used to be made with stairs that went to the attic. Here children... Read More »
The rafters of a patio overhead serve two main purposes. They're meant to firmly hold the overhead in place, and they're meant to add decoration to your patio. Patio overhead rafters are moderately easy to assemble and install. Read More »
egress window with header required nwmod39 Building & Construction 19 08-25-2009 08:28 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 07:11 PM
correct window framing? incorrect header jingles63 Building & Construction 2 05-02-2009 03:49 PM
How to drill into metal window header? BrandonDL Carpentry 4 01-29-2009 07:01 AM
Non-load bearing window header in exterior wall timelyirony Building & Construction 3 12-08-2007 06:15 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
