Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-07-2011, 04:05 PM   #1
Bottom Plate for Non-Load Bearing Wall
I've built a new interior wall in my bathroom that runs parallel with the ceiling and floor joists. The wall is about 7 feet long and 9 feet high. I read through my handy DIY book and built the wall accordingly making cross-joists in my attic every 16 inches to secure the top plate to.
For the bottom sole, I took my plumb-bob and lined up the bottom plate screwing it down to the 3/4" OSB sub-floor at least every 16 inches (probably more like every 10"). The sole is about 3" to the right of bottom joist, but not exactly lined up so it's not secured to it. I couldn't add another joist or cross-joists below because of plumbing in the way. Is this an issue for a non-load bearing wall?
This is actually a shower wall that has 1/2" hardibacker secured to it.
Thanks in advance
cobrakai is offline   Reply With Quote
Old 02-07-2011, 10:23 PM   #2
remodeling pro
Should cause no trouble as long as it is secured to the subfloor so it can not move laterally; and it sounds like you have done that.
troubleseeker is offline   Reply With Quote
Old 02-08-2011, 12:56 PM   #3
Thanks for the reply!!
Load Bearing (point Load) Wall Removal Advice Stringer9 Building & Construction 5 11-09-2010 11:14 AM
Removing a load bearing wall, adding a beam ? Lakedriven Building & Construction 9 11-02-2010 08:12 AM
Modifying a Load Bearing Wall acme54321 Building & Construction 1 08-21-2010 12:29 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 04:44 PM
Load Bearing Wall or not?? dtmbizzle Building & Construction 3 07-16-2007 08:12 AM
