Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-05-2009, 12:10 PM   #1
Bottom plate for new interior wall
Ok I'm going to be helping a friend of mine put a closet in his house. There is already a space in the room that is recessed back some so all we need to do is put up a wall with a door and then we have a closet. The room has hardwood floors and i was wondering if we need to pull up some hardwood an nail it into the subfloor or if it would be ok to attach it to the hardwood itself, i know if we attach it to the hardwood it could pose futur problems if they ever wanted to remove the hardwood and replace it with something else but is there any other reason why not to do this or would it be acceptable.
912jake is offline   Reply With Quote
Old 09-05-2009, 12:18 PM   #2
Xtreme DIY'r
No need to pull up the hardwood
Do the floor joists run perpindicular to the wall you want to build?
If so I'd try to nail into the joists
Old 09-05-2009, 12:27 PM   #3
I dont know yet I havent had a chance to look, ill check although i dont think it would be necessary to go out of my way to hit a joist since the wall is really just to complete the closet and will not be load bearing, but I could be wrong on that.
Old 09-05-2009, 02:15 PM   #4
Moderator
Not absolutely necessary, in fact if the sub-floor is 3/4" and the hardwood is 3/4", and the bottom plate is 1-1/2", that total is 3" - as long as most hand and gun nails used for framing.
If the closet is to convert the room to a bedroom, make sure you have egress (escape) in case of fire, as a window or door to the exterior: http://www.taunton.com/finehomebuild...s-windows.aspx
Be safe, G
Old 09-05-2009, 03:08 PM   #5
Yeah this is to make a bed room and there is a window to the exterior, also thats what i was thinking as far as the 3/4 hardwood and subfloor i figured it would be ok. The area of the room actually looks like it was meant to be a closet they just forgot to the put the front wall on so im gonna take care of it, thanks for the help.
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
attach bottom plate to exizting slab Constant Improvement Building & Construction 1 02-04-2009 01:36 PM
Boring holes in a load-bearing bottom plate benjamincall Building & Construction 22 01-21-2009 10:05 PM
Rewiring old house, Hit brace in outside wall, Safe to drill through Bottom Plate. twilightcall Electrical 2 06-30-2008 12:36 AM
Bottom plate fastening? Taipans Building & Construction 22 02-27-2008 02:41 PM
