Bottom Plate For Framing In Basement - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-07-2011, 09:00 AM   #1
Bottom Plate for framing in basement
Is it benefitial to use construction adhesive on the treated bottom plate when I frame my basement? I bought some 50' rolls of sill 3.5" foam to put under the bottom plate as I thought that would help keep the plate from rotting over time. If I use that though it'd be pointless to use the construction adhesive.
Why is adhesive even used when you are fastening the bottom plate into concrete. Aren't hardened steel fastners enough?
griffinst is offline   Reply With Quote
Old 03-07-2011, 11:25 AM   #2
Rewards Points: 5,336
You use pressure treated wood in contact with concrete. I haven't used masonary nails in a long time. I either shoot them in with a nail gun or screw them in with tapcons. Both with adhesive.
Ron
Old 03-07-2011, 11:39 AM   #3
Solutions (handyman)
Rewards Points: 364
Sill plate
I have seen both methods used. Usually, when the bottom plate is not pressure treated wood, a sill membrane is used to seperaste the concrete and the wood. This is where embedded bolts in the concrete extend up through the bottom plate and are bolted, holding the bottom plate in place. If the bottom plate is pressure treated wood, sill foam is not necessary. Having said that, any basement wall that you may build should have a barrier bewteen the wood and the cement floor (unless it's pressure treated) so the sill foam can be used there. As to the adhesive, you are correct is that it is to be used where you have two solid surfaces to join together.
Mark Harvey is offline   Reply With Quote
Old 03-07-2011, 01:33 PM   #4
I just thought the foam sill would help with insulation on the bottom plate on the floor. I just don't see the necessity to use adhesive on the bottom plate as well as concrete anchors. A concrete anchor every 2' should be plenty of hold for a non-load bearing wall.
Old 03-07-2011, 02:33 PM   #5
Tizzer's Avatar
Rewards Points: 460
Adhesive is good when you have a really short bottom plate like a bath or closet doorway. Fasteners may split the wood.
If haven't already, you might want to check for the correct type of fasteners for that treated wood.
Tizzer is offline   Reply With Quote
The Following User Says Thank You to Tizzer For This Useful Post:
Dusty1 (03-19-2011)
Old 03-21-2011, 11:15 PM   #6
Skip the adhesive. In my basement non load bearing walls I used foam under PT bottom plates secured with tapcons. Works great
JordanPHI is offline   Reply With Quote
Old 03-22-2011, 10:42 AM   #7
Thanks, I did the same thing except I used split drives. I put the foam under the PT plate as well.
Old 03-24-2011, 12:12 AM   #8
Registered User
Rewards Points: 5,516
Hah, what are the odds..... Basement baseplates
Gary
Leaking above windows in basement - sill plate sondraaf Building & Construction 2 02-28-2011 10:33 AM
Replace basement sill plate Bcoleman6 Building & Construction 7 01-15-2011 10:01 PM
Cut Doorway Bottom Plate on Concrete OhioDon Building & Construction 3 12-09-2010 11:19 AM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
doing up a basment littleparr Building & Construction 7 04-08-2008 08:28 PM
