Bookshelf Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-15-2008, 12:45 PM   #1
Bookshelf question
I was thinking about adding some bookshelves in my basement remodel and wanted to ask you people about what wood would work best for the shelves themselves. I can just use cabinet plywood for the sides and veneer from fronts, but it really irritates me when I see a bookshelf that is bowed from the weight of the books. What's the best way to avoid that?
Thanks!
Eric
perpetual98 is offline   Reply With Quote
Old 01-15-2008, 02:48 PM   #2
How long will the shelf be?
redline is offline   Reply With Quote
Old 01-15-2008, 03:02 PM   #3
I'm still in the design phase, so they can be as short or as long as need be I suppose. Probably somewhere around 2-3' wide?
Old 01-15-2008, 05:44 PM   #4
Rewards Points: 5,336
Shelves bow due to over loading the shelf and/or making the shelves too wide. A 36" wide, single thickness ply= bow potential. A 24-28 " shelf would be hard pressed to bow.
Ron
Old 01-15-2008, 09:43 PM   #5
Would making the shelves out of a hardwood be less likely to bow, or are some manufactured woods "stiffer"?
Old 01-16-2008, 09:55 AM   #6
If you use plywood for the shelves you can add a 1-1/2 x 3/4" solid edge to the front of the shelf. It will cover the end grain of the plywood and make the shelves stronger. I Thought I had a pic but couldnt find it.
RTRCon is offline   Reply With Quote
Old 01-16-2008, 02:12 PM   #7
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
The pretty face can be used as integral support, like in cabinets and furniture. The backer board should serve some support, even if it is 1/8" thick. You could use a ledger strip under the back of the shelf to add strength.
Check out the shelves in the library.
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 01-16-2008, 03:35 PM   #8
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
You can add a 1 1/2" strip of real wood to the front of the plywood to cover the edge and help it not bow. Also something that I like is using stair treads, the pine tread come 11 1/4" by up to 16' so you cut any leagth you want and the at a full 1" thick it's a lot stiffer.
Kingfisher is offline   Reply With Quote
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
New service Question Onytay Electrical 1 10-24-2007 06:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
