Bookcase Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-27-2013, 02:49 PM   #1
Bookcase door
Hi guys
I'm on finishing touches to my basement development, and I'm having a few issues with a bookcase door and frame that I have made.
The frame I've made sits flush and level in the rough opening, the bookcase door is cut plumb and stand alone is perfect in every way.. Level etc.
My problem is when I hang the door, the top of the door is flush with the frame but the bottom if the door sits 2" behind the frame. I've tried adjusting and moving hinges to make it fit properly but nothing I do seems to bring the bottom into the right position.... Any ideas???
powdaking is offline   Reply With Quote
Old 05-27-2013, 03:50 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,104
the bookcase itself isnt built plumb, it has whats called a wind in it.. because of this the door wont close properly youll have to try to adjust the case itself so the door operates
woodworkbykirk is offline   Reply With Quote
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 07:08 PM
closet door to bookcase XXSTEVEO66 Windows and Doors 0 05-29-2012 06:28 PM
Exterior Door won't seal Rhomadri Windows and Doors 8 04-28-2012 09:27 AM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 05:45 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 08:43 AM
