Bolting Deck Ledger - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-23-2008, 10:50 PM   #1
Rewards Points: 154
Bolting Deck Ledger
I'm in the process of attaching a 20' long 2x10 deck ledger (PT Doug fir). The 1/2" holes I've drilled out are real snug where I have to tap in the bolts half the way with a hammer. I read somewhere where they used a 9/16" drill for the 1/2" bolts to allow for shifting and shrinkage. Are my bolts too tight? I did let the lumber dry at my location for a month.
ovahimba is offline   Reply With Quote
Old 07-24-2008, 08:27 AM   #2
Registered User
Termite's Avatar
You could drill the holes through the deck rim a little bigger if you want, but must not overdrill the holes in the house's rim. The lag threads must engage the wooden house rim in order to be effective.
Old 07-24-2008, 12:04 PM   #3
Can a ledger board be secured to a building by bolting it to the wall studs.
I'm thinking ROOF ledger board, rather than a deck ledger board.
Old 07-24-2008, 01:14 PM   #4
Registered User
Termite's Avatar
Yes, this is common on split-level homes.
Old 07-24-2008, 05:50 PM   #5
BUILDER / REMODELING CONT
buletbob's Avatar
Question
BOLTING IT TO THE WALL STUDS??? Or did you mean Lagging screwing.
just want to clarify the difference. BOB
Old 07-24-2008, 08:22 PM   #6
Registered User
Termite's Avatar
Yeah, I meant lag screws. Not bolts!
Old 07-25-2008, 01:20 PM   #7
Me too! I meant lag-screws. Of course bolts would work if access to the opposite side were available.
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
ledger for large deck area mnulty Building & Construction 3 07-20-2008 07:01 AM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 11:05 AM
Deck Ledger To House Osb Rim Joist munson_11 Building & Construction 7 04-19-2008 12:41 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
