Bolt Terminology - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-18-2014, 03:38 PM   #1
Rewards Points: 99
Bolt terminology
Hello,
Building a project and diagram calls for installing up stop and down stop bolts. I don't have a clue what they are talking about. Please help!
Thank you so much.
Yours truly,
Mr. All thumbs
kirwinjd is offline   Reply With Quote
Old 01-18-2014, 05:14 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 596
Is your project a garage door?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-18-2014, 05:28 PM   #3
Rewards Points: 14,026
Never heard of those terms when naming the parts of a bolt.
Just a function bolts can preform.
Old 01-18-2014, 07:00 PM   #4
Rewards Points: 99
I'm building a swing toy for my kids out of PVC and it calls for these bolts to attach 3" pipe to the 1 1/4 pipe.
Thanks for your reply.
Old 01-18-2014, 07:11 PM   #5
Rewards Points: 2,638
That terminology is sometimes used where a bolt is used as an adjustable stop. If some object is moving up and down, and a pair of bolts are used as adjustable stops, then one would be an up-stop, and the other a down-stop.
SPS-1 is offline   Reply With Quote
Old 01-18-2014, 07:21 PM   #6
You are aware PVC has 0 side load strength.
It will sag just under it's own weight.
kirwinjd (01-18-2014)
Old 01-18-2014, 08:37 PM   #7
Rewards Points: 99
Great. Thank you so much.
Old 01-18-2014, 08:40 PM   #8
Rewards Points: 99
You would think so. Im Building it according to plan. Total length only about 4 feet. PVC is schedule 40. Hope the guy who designed it knew what he was talking about.
Old 01-19-2014, 07:04 AM   #9
PVC is also is not UV protected and the fittings and pipe will break down and crack.
Old 01-19-2014, 07:59 AM   #10
Ole Wood Worker
BigJim's Avatar
Rewards Points: 596
You don't want to get silicone on PVC either, it will snap under no pressure at anytime.
Jim
Old 01-19-2014, 08:42 AM   #11
Rewards Points: 99
Thanks for the info on that. Good reminder on the UV issue and I wasn't even aware of not using silicone.
It will be an indoor toy at all times. It will be like a flying simulator with gimbals and castor bearings that will be controlled with a joy stick.
The plans look well done, detailed and very professionally done. Plan calls for using 3", 2", 1 1/4" and 1" PVC. So far Ive cut and pieced together all of the pipe without any problems. The bearings will allow you to pitch and roll as you sit inside of it. Looks like a lot fun but I was confused on some of the terminology like the stop down and stop up bolts.
The Following User Says Thank You to kirwinjd For This Useful Post:
BigJim (01-19-2014)
Old 01-24-2014, 12:46 PM   #12
Mold!! Let's kill it!
Rewards Points: 2,012
Would love to see a picture of this project when it's completed.
Lifting and hoisting RWolff Safety 2 06-23-2013 01:43 AM
Broken bolt emerging from cement Mallethead Concrete, Stone & Masonry 7 06-03-2013 02:37 PM
removing large mounting bolt...should I worry about weakening the stud? matt_gold Drywall & Plaster 2 03-21-2013 12:23 PM
en Flange bolt. Not sure how to proceed. latenight Plumbing 4 08-07-2012 05:01 PM
Need Hex Bolt for Older Velux Skylight xquercus Roofing/Siding 0 05-26-2010 01:19 PM
