A Board, With No Straight Lines - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-26-2011, 06:46 PM   #1
Rewards Points: 350
A board, with no straight lines
Let's say I have a piece of wood, maybe about 3 feet by 3 feet. I am trying to make drawer faces out of it. However, I can see that all four sides were cut unevenly....they are wavy, and on two sides, so wavy that the board won't stay standing on its side.
How do I cut some faces out of this, when I have no good straight edges to start from? there must be an easy answer!
dougp23 is offline   Reply With Quote
Old 12-26-2011, 06:50 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Clean up the sides by re-cutting the board. You will have a square board when you measure the two diagonals (like the way you measure a tv) they need to be the same measurement.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-26-2011, 06:52 PM   #3
DIY staff
Rewards Points: 7,174
Tack it to a straight scrap of plywood and push that through the table saw--
Clamp a straight edge on top--use a Skill saw--
Clamp on a straight edge and use a router--
Run it through a Jointer--
Need more?
Tom Struble (12-26-2011)
Old 12-26-2011, 06:53 PM   #4
KemoSabe
loneframer's Avatar
Quick and easy way is a jointer to get started, but if you don't have one a router and a straight edge will get you started. Clamp a level or something similar to the board and run a router with a straight cut bit along it. This will give you an edge to run against the table saw fence. Rip to desired widths and use a mitersaw or radial arm saw to square the ends.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 12-26-2011, 06:55 PM   #5
KemoSabe
loneframer's Avatar
You're quick on the draw Mike.
The Following User Says Thank You to loneframer For This Useful Post:
oh'mike (12-26-2011)
Old 12-26-2011, 06:56 PM   #6
Rewards Points: 350
Thanks guys!
I really need to improve my router skills. The drawer faces I am making will have sort of like a bevel on them, about 1" in all the way around. But I am so new to the router, I really can't think of a way to do it! Maybe I need a good beginner's router book....
Old 12-26-2011, 06:58 PM   #7
Rewards Points: 350
Amazing, ain't it! In 9 minutes, I have three people posting ideas.
This site is great!!!
Old 12-26-2011, 07:03 PM   #8
Rewards Points: 14,026
Look into a router table.
Old 12-26-2011, 07:06 PM   #9
DIY staff
Make the time to learn that router---
I have a clamping jig just for straightening edges --great time saver-
A router table can be made out of a scrap piece if 1/2" plywood --some more scraps for a fence
That router will help you move your wood working up a step or two---Mike---
dougp23 (12-27-2011)
Old 12-26-2011, 07:32 PM   #10
Rewards Points: 350
I usually start things from the wrong perspective....
I bought a router table, THEN I bought a router! Thankfully the router fits in the table, but really, I have no idea how to do anything with it. I have some bits and have tried some chamfer work, but I got frustrated.
Everyone I know says the same thing "learn to use that router is such a versatile thing". I think we have a woodworking store a few towns over, and every other month or so he offers a "Begginer Router" class. probably wouldn't hurt me to go!
Old 12-27-2011, 09:41 AM   #11
Cabinet maker
Augie Dog's Avatar
Once you have your drawer fronts broken down to size, you can bevel the edges with a table saw.
Check out this thread that I did some time ago about beveling with a table saw.
http://www.contractortalk.com/f13/be...utorial-56493/
Augie Dog is offline   Reply With Quote
Old 12-27-2011, 09:48 AM   #12
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Sounds as if the next thing you need to buy is a "Framing Square".
Are ya kiddin' me? This guy doesn't know how to square a piece of irregular-sawn plywood and he's going to have a joiner sitting in the corner of his garage?
XXX
Old 12-27-2011, 11:12 AM   #13
EIT/DIY'er
I'm gonna go with Bud on this one.
You can do this many different ways, depending on what tools are available. Assuming you have a limited shop, a circular saw, straight edge, and framing square will do a pretty good job for you.
If you're using plywood, I'd suggest to use the proper blade for plywood and use masking tape over your cut lines else you will have some ugly tearout.
Lattimer is offline   Reply With Quote
Old 12-27-2011, 11:16 AM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Any splintering and tear out can be reduced and controlled by first scoring the line to be cut using a utility knife. Then run the saw blade along that score.
XXX
shower rebuild - need help with backer board & green board johndoe12345 Tiling, ceramics, marble 2 11-27-2011 01:16 PM
fiberglass over rigid foam board in cantilever? KatieAK Building & Construction 3 11-17-2009 07:48 PM
water lines on slab toolbelt Tina Plumbing 6 05-21-2009 07:05 PM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 12:23 PM
Laminate Lines Not Straight... sootybuttercup Flooring 7 09-01-2006 02:32 AM
