Board Cutting Problem - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-04-2008, 07:27 PM   #16
ADKstorm's Avatar
Lightbulb
thanks for the constructive tips
Originally Posted by RippySkippy View Post
Gottcha.
"Usually" the tasks associated to drywalling can be brutal on finished things like that. Not just the dust, but sanding, and texturing.
I would suggest you cover the shelf with brown paper, cardboard and plastic, in that order. The brown paper would go from the lower wall over the shelf to the upper wall following the bends at the corners. The cardboard would run to the plate only on the top of the shelf. The plastic would go from the lower to the upper wall following the bends at the corners. The brown paper may be overkill...but I hate cleaning up DW messes and possibly fixing dings which hopefully the cardboard will provided some cushion for the top. When your done DW, take a sharp knife and cut the plastic and brown paper and cover the small gap with trim of some sort.
Good luck to you...post more pictures when you get it completed.
Thanks! I think my plan is the back edge of the shelf and bottom edge of drywall will be hidden with cove molding:
Will post finished pics in future
ADKstorm is offline   Reply With Quote
Painting the inside edge of cutting board slots 1655graff Painting 8 01-28-2008 07:51 PM
cutting bead board scatterbrain General DIY Discussions 3 01-09-2008 08:13 AM
creaking wall board or possible hvac problem altoon HVAC 2 01-03-2008 01:40 PM
Problem with Payne ultra 90 Mark H HVAC 19 12-31-2007 08:25 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
