Blocking Plate Spacing - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-11-2010, 06:24 PM   #1
Blocking plate spacing
Installing a framed 2x4 wall in an attic with a cathedral ceiling, rafters are 9 feet from knee wall to collar tie on both sides and collar tie is 8 feet across at the top. How far apart should my blocking plates be to attach the top plate of the wall? Are 2x4 plates o.k? Wall will have a 36 inch wide door and be approx. 19 feet long. I can place the wall at different spots so can I attach it directly to the rafters and collar tie? Thanks
Jamech
Jamech is offline   Reply With Quote
Old 04-11-2010, 06:30 PM   #2
what are blocking plates?
The older I get the better I was
Old 04-11-2010, 06:35 PM   #3
Registered User
Rewards Points: 526
The blocking plates (drywall backing ?) should be no more than 24" on center to support drywall and give solid lateral support to the wall.
"I can place the wall at different spots so can I attach it directly to the rafters and collar tie?" ------ If you want to.....
Be safe, Gary
Replacing Section of Sole Plate RM575 Carpentry 3 03-28-2010 09:31 AM
top plate just attached to drywall bluefitness Building & Construction 5 03-18-2010 07:20 AM
HVAC and Joist Blocking Question bassprokd HVAC 3 02-25-2010 05:42 AM
Getting Steel Plate Flush with Concrete Floor MrBill_DIY Flooring 7 11-29-2009 08:54 AM
OK to drill holes in top plate to run conduit? troll5501 Carpentry 4 05-11-2008 08:33 PM
