Black Granite Back Splash W Hickory Cabinets? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-07-2011, 09:32 PM   #1
Black granite back splash w hickory cabinets?
We are remodeling kitchen. Counter will be beige dafne kalahari silestone slab only. No backsplash. I would like to use black granite 12 x 12 tile as a backsplash all the way up to upper cabinets. Cabinets will be hickory with a pretty natural finish. Black appliances. Too much black?
IlliniFan1036 is offline   Reply With Quote
Old 03-07-2011, 10:00 PM   #2
Rewards Points: 410
I probably would put a short backspash of the same color up as the counter tops.
We have hickory cabinets ( medium stained ) with it looks to be the same
color counter tops only in synthetic HI-max.( corian type )
Appliances are stainless/Black , and there are many under cabinet lights.
You want kitchens bright , to much black IMO but its your kitchen.
High Gear is offline   Reply With Quote
Old 03-07-2011, 10:02 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Too much black?
Way too much IMHO.
XXX
Old 03-08-2011, 09:18 AM   #4
sounds like you need a designer not a diyer
mrgins is offline   Reply With Quote
Old 03-09-2011, 10:22 PM   #5
Rewards Points: 37
We just finished our kitchen and did a natural stone backsplash that goes up to the upper cabinets and up to the ceiling by the stove and sink. Cabinets are birch with a light cherry stain. The stone is beige/tan/some darker browns and it is as dark as I would go. In addition we added LED under cabinet light strips which lights up the stone and adds brightness to the kitchen, something the black would take away in my opinion.
Good Luck.
tvanharp is offline   Reply With Quote
Old 03-12-2011, 09:40 AM   #6
We remodeled our kitchen two years ago. We have natural hickory cabinets with a lot of random grain. They also have black satin crown molding and trim on bottem of upper cabinets with under cabinet lighting. Knobs and pulls are black as well. The countertops and backsplash are black granite with gold fleck. Appliances are stainless and black. Paint is Ben Moore HC-112 Tate Olive which is a fairly dark green. We also have a garden window to allow the south sun in, as well as 5 can lights in the ceiling. For me this is not too much black, too dark or anything of the sort. I think it's all about the contrast of dark and light. But, that's my preferance. Unfortunately cabinets, counters and backsplash are harder and more costly to change than paint. Try a paint that is of similar color to the backsplah that you are considering. that should give you some insight hopefully. Good luck.
kboyz is offline   Reply With Quote
Old 03-12-2011, 09:45 AM   #7
One other detail. The floor is Armstrong Duraceramic Midnight. It's a composite material is black based with dark grey swirling in the design. Toe kicks are also black.
Old 03-12-2011, 12:03 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The floor is Armstrong Duraceramic...
Last I heard...Duraceramic was made by Congoleum.
Just sayin'.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
kboyz (03-13-2011)
Old 03-13-2011, 07:14 PM   #9
You are correct. My mistake.
Tiles before or after kitchen cabinets? nipab Remodeling 9 01-05-2015 11:19 AM
Back Splash Tile Over Old Sheet Rock? Stcrosby Remodeling 3 01-03-2010 12:46 PM
Back Splash Tile Help TTran Building & Construction 15 01-12-2009 03:03 PM
Tile Back splash over stove - Waste of time? Mr Chips Flooring 5 07-06-2008 01:46 PM
Installing A Back Splash bobo Carpentry 3 09-09-2006 02:36 PM
