Biscuits - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-09-2012, 07:37 PM   #16
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
For work piece edge alignment the MLCS Slot cutters will work fine, but Slot cutters will not provide the same strength joint as a convertional slot cutter
Another shortcoming is that there is no slot cutter for the #0 or #10 sizes.
Disclaimer
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
woody4249 (07-09-2012)
Old 07-09-2012, 10:48 PM   #17
jschaben
Rewards Points: 502
I'm not a big fan of biscuits so I don't use them very much. But, for fit, #0 uses a 1/8" (3mm) cutter and #10 uses a 5/32" (4mm) cutter. The length can be adjusted with the router travel. Granted, there is a little space inside the biscuit groove when the biscuit is inserted. About the only problem using biscuits with a router is trying to get them in the center of a panel, instead of an edge. I still submit that if making a choice between having a router and a biscuit joiner, the router is far more versatile.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 07-10-2012, 06:58 AM   #18
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
Centering a router on the edge of a part is made easier with this jig.
http://www.rockler.com/product.cfm?page=17847
Slots in the face of a panel are achieved with the aid of a straight edge offset by the router base diameter divided by 2. If the grove you cut is a little loose, use more glue.
Before biscuits were invented we would use a spline which is no more than a thin piece of plywood or lumber dado-ed into each part.
Mike
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
Old 07-10-2012, 09:37 AM   #19
jschaben
Rewards Points: 502
Mike
Hi Mike - Absolutely right. I suppose I would use my dado jig were I to ever do that. No more than I've used biscuits in the past, I don't really see it in my future.
I think what Mr Lavery was referring to as a bad "fit" is that the radius of the router slot cutters doesn't match the radius of the biscuits which, to me, is a non-issue.
The thing with the Rockler jig is you are limited to how closely you can get to the end of the stock before the guide pin falls off. There are workarounds (usually are) but one needs to be aware.
John Schaben
Old 07-10-2012, 10:00 AM   #20
woody4249's Avatar
Rewards Points: 156
All you have to do is clamp on an additional 6" as a temporary extension
Old 07-10-2012, 12:36 PM   #21
Tool Geek
PaliBob's Avatar
For anybody still thinking of a Biscuit Joiner
But rather than one in the $100 range
I would not be afraid to get one of these
Disclaimer
& Stay Safe
.....Bob Lavery
senior-chief (07-10-2012)
Old 07-10-2012, 01:51 PM   #22
woody4249's Avatar
Rewards Points: 156
I love that place......look for the 20% off coupon in mags and plan your purchase.
Among other things, I bought a 4" grinder there 5 years ago for $19..........still works great and I've used the heck out of it.
Old 07-10-2012, 02:10 PM   #23
"Tis a pleasure to listen to the masters" I'll be gettig an inexpensive biscuit-joiner around the 20th---That's when Unc-Sam sends the pension check. He better after 37 yrs of Sam service---Have a goodin'
senior-chief is offline   Reply With Quote
The Following 2 Users Say Thank You to senior-chief For This Useful Post:
PaliBob (07-10-2012), woody4249 (07-10-2012)
"DIY" - cooking/baking - story rossfingal Off Topic 1194 12-23-2015 12:55 AM
