07-05-2012, 09:15 AM
#1
Biscuits
Question: Since I do not own a biscuit joiner, how did people insert biscuits, i.e., 2 x 6's? Hopefully my learning curve continues to grow....Thank you
07-05-2012, 09:21 AM
#2
the Musigician
Biscuits
Sorry, I don't understand your question. To use biscuits, you need a biscuit joiner tool.
Then they glue in place. Pretty basic.
DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes!
The Following User Says Thank You to DangerMouse For This Useful Post:
07-05-2012, 09:49 AM
#3
Biscuits
Depending on what you are doing, dadoes with splines or holes with dowels may be viable alternatives; otherwise, as DM said, biscuits generally require a biscuit cutter.
07-05-2012, 04:10 PM
#4
Biscuits
Thank you too both you guys. Time to purchase a biscuit joiner---have a goodin'
07-05-2012, 06:46 PM
#5
Biscuits
You don't need a biscuit joiner,you can use a router and a slot cutter in a table
07-08-2012, 10:42 AM
#6
Retired Cabinetmaker
Biscuits
Biscuits typically are made from compressed plywood and come in different sizes. They are approximately 3/16" thick and shaped like an American football. Once glue is applied and inserted into the slot, they expand and form a tight fit. Wood dowels do the same thing and are usually 8mm in dia.
These however are not so forgiving and accuracy with boring is paramount
These are utilized in the cabinet industry for joining panels and are not usually considered a "joinery" method for carpenters with structural material.
When joining 2x6's in a "T" joint there are three traditional ways of creating a sturdy joint. Other than a "Butt joint" it could be "Half lapped", morticed, or trenched with a "Dado"
If this joint is considered a "significant structural point", additional support can be gained by use of a joist hanger, metal bracket or strapping.
As a biscuit joiner has only one purpose, it may be to your advantage to purchase a router and utilize a box bit router cutter. With the use of jigs you will be able to perform the same task and have a very versatile tool for other projects.
Mike
"I'm not as green as I am cabbage looking"
The Following User Says Thank You to woody4249 For This Useful Post:
07-08-2012, 12:04 PM
#7
Biscuits
get a Kreg pocket screw kit instead
The Following User Says Thank You to Tom Struble For This Useful Post:
07-08-2012, 12:10 PM
#8
Biscuits
Oh.....I forgot about that........best tool I ever bought
Mike
07-08-2012, 12:36 PM
#9
Tool Geek
Biscuits
.....Time to purchase a biscuit joiner..........
You've got it. Biscuits need an oval shape hole.
Trying to use a router or table saw while fine
for splines won't cut it for biscuits.
Also biscuits are not made from plywood
but usually from compressed Beech.
They are made to expand to make a tight joint.
That's why it's best to store them in an
airtight container.
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
07-08-2012, 01:00 PM
#10
Biscuits
airtight container.
I stand corrected..........I really should know better having used them a gazzillion times
07-08-2012, 01:06 PM
#11
the Musigician
Biscuits
Personally, I'm still trying to imagine using biscuits to connect two by sixes!!!!
(unless someone can explain to me what a 2X6' is! " = inches, ' = feet )
DM
07-09-2012, 07:24 AM
#12
Tool Geek
Biscuits
....how did people insert biscuits, i.e., 2 x 6's?
Festool makes a large mortise tool (The Domino XL) that evolved from the wood biscuit technology.
Anybody with an extra $1250 can just get started with this Tool.
& Stay Safe
.....Bob Lavery
Reason: sp
07-09-2012, 03:03 PM
#13
Biscuits
Oh man, $1250 for biscuit joiner? Send me back to Vietnam--Ha--Hell, I am a newbie and probably need more advice after all. I was thinking a used B.J--Festol is way out of the way for this old sailor--Thank you, Mike
07-09-2012, 03:14 PM
#14
the Musigician
Biscuits
I know, my son and I were just looking at that too..... I spent less on our riding mower! LOL
You have to admit though, if you had the need, that's a pretty sweet tool! Po)
(Go Navy!)
DM
07-09-2012, 03:17 PM
#15
jschaben
Biscuits
Here's a little more affordable version.
http://www.rockler.com/product.cfm?p...2&site=ROCKLER
Might help, a lot, to know just what you are working on.
Here is a system for using a router to put in biscuits:
http://www.mlcswoodworking.com/shops.../biscuits.html
Personally, I would get the router over the biscuit joiner as the router is much more versatile. That is, if you have neither.
John Schaben
"Where all think alike, no one is thinking very much" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
The Following User Says Thank You to jschaben For This Useful Post:
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
