Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-09-2009, 06:25 PM   #1
Default birch cabinet with a hole
I recently inherited an old wash stand cabinet made out of birch. The stand is well over thirty years with alot of wear. On one of the cupboards there is a huge hole. To be exact it looks to be where the hinge once was. I was wondering what would be the best way (without replacing the door) to fix the whole because it is in a noticable place I would like something (no matter how creative or how much effort it takes) as natural looking to the original condition as I could get. The door also has some edge work on it
thanks in advance for any suggestions
MYCABINET is offline   Reply With Quote
Old 10-10-2009, 01:31 AM   #2
Building codes guy, Mod
thekctermite's Avatar
Is the door painted? If so, Bondo auto body filler is absolutely your best bet. Works great for filling holes and cracks that will be painted over.
If the wood is stained can you post a picture of what you're dealing with?
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
Old 10-10-2009, 10:05 AM   #3
Default whole cabinet
This is the only picture that i have at the moment (I will post another one of the damage later on) sorry i'm not at home at the moment. On the front right door in the bottom left corner you can kinda see it. I know this probably isn't even worth posting b/c you can't see how bad it is but I am really anxious to find someway to fix it as I think it's a great cabinet. I will post another pic later today, but hopefully this one can help a bit for now?
Thank you
Old 10-10-2009, 02:32 PM   #4
Civil Engineer
That is a very nice looking cabinet. Post a better picture of the damage, then we can discuss options for repair.
Old 10-10-2009, 06:52 PM   #5
Default close up pic of the damage
ok I'm having a very difficult time posting the pictures of the damage close up. if you want I can send them via email
Old 10-11-2009, 01:42 PM   #6
Household Handyman
Sorry but that problem cannot be fixed--ship the cabinet to me for safekeeping. Seriously--The cabinet is a keeper for sure. It does appear to have been stained/varnished some years ago and I like that look. Now: you are referring to a "hole" but are you maybe talking about a "mortise", where the wood was cut out for a hinge orginally, maybe newer hidden hinges have been installed, and now the mortise is showing? IF this is the case-and IF you have a cabinet shop, or restoration shop in your area, they may have some veneer material they just might sell to you. I doubt you will ever match this so as not to be seen, if painted--then maybe, but not with that stained look. Using thing veneer you could fill in the mortise area and try to match the stain as close as possible. OR- maybe go back to the exposed hinges for the look that it had orginally, that would be my choice. The have some beautiful exposed hinges today that would compliment the cabinet. Good Luck, David
More On This Topic
In this next clip I'm going to show you how to prep your area and get it ready for staining. Okay, the first thing you want to do is have your drop cloth and, in our materials or tools we have our drop cloth, we're going to lay down our drop cloth first... Read More »
When choosing dental veneers, you may be offered a choice between traditional and da Vinci veneers. Da Vinci veneers are the most popular choice among porcelain veneers and offer several advantages the competition does not. Still, you need to compare the... Read More »
While veneers are extremely durable, they are not meant to be permanent. Even with the best of care, a veneer will eventually end up chipped, broken or cracked and will need to be repaired. How the repair is done depends on many factors, including the... Read More »
If you are considering veneers, you will probably be offered two choices by your dentist: resin or ceramic. While most dentists will recommend ceramic because of the many advantages associated with this type of veneer, you should carefully compare the... Read More »
Once your dental veneers are in place, you may not need any follow-up appointments. Cleaning and caring for your veneers can be done at home quite easily and without the need for any special equipment. While your teeth may have some sensitivity for a few... Read More »
hole left by medicine cabinet Mack Remodeling 4 08-27-2009 08:02 PM
pocket hole joinery for cabinet doors? Jeremy Hillary Boob, PhD Carpentry 4 03-09-2009 07:26 PM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 11:26 AM
How does hole in Gas Furnace cabinet contribute to carbon monoxide in crawl space. Chris H HVAC 5 10-08-2008 08:20 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 12:28 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
