| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Checking Corners on a Home Quality Inspection
by Expert Village
Hi! I'm Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a quality walk through on this house. Your corners come together in the home. You know look at the way those come together and make sure that they... Read More »
How to Measure When Installing Drywall
by eHow.com
Using full sheets of drywall--also called sheetrock--is recommended whenever possible, but designing a project perfectly around the standard size of a sheet of drywall isn't that easy. So measuring when installing drywall and cutting the sheet to your... Read More »
Positioning Air Barriers for Home Insulation
by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this house. So just to clarify this right here is going to have drywall on the face of it. We've... Read More »
Making A Jeweled Frame
by Expert Village
This is John Mendez with Expert Village and I am working on a jeweled frame. I have already started part of it here on the corner and you can use all size beads. I try to stay no larger than about eight millimeters and anywhere down to about one... Read More »
Proper Air Barriers for Home Insulation
by Expert Village
Hi! My name is Joshua Lindsey with CFM Science Building Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. The first thing we are going to look at is the overall alignment throughout the house. What... Read More »
