Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 05-02-2009, 11:09 AM   #1
bifold doors
I am installing 2 24" bifold doors side by side. Can anyone tell me the rough opening that I should build. Thanks a bunch for your help
larry58 is offline   Reply With Quote
Old 05-02-2009, 11:31 AM   #2
bifold doors
Depends if your going to wrap in wood or drywall. A wood wrap is going to require a 50" x 82" rough opening. 1/2" drywall will require 49 1/4" x 81 1/2" rough opening if your using drywall bead prior to fininsh. However, not all bifolds are built the same, most bifolds are 79" in length, some are 80". You will need to an inch to the above if your bifolds are 80".
Mop in Hand is offline   Reply With Quote
Old 05-02-2009, 01:41 PM   #3
Drywall contractor
bifold doors
Most have rough opening size on the package. Go to the store and check....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 05-02-2009, 02:30 PM   #4
Moderator
bifold doors
Don't forget the finished floor thickness....... Be safe, G
Bifold doors driving me crazy! Gevans17 Carpentry 8 01-29-2009 05:12 PM
Help installing bifold doors MT Stringer Carpentry 5 11-05-2008 11:24 PM
UGH! A lesson for new Pre-Hung Doors javan General Discussion 6 08-08-2008 08:47 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
Bifold Laundry Closet Doors? DIYtestdummy Remodeling 2 02-14-2008 03:38 PM
