Bifold Doors - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-26-2012, 11:50 AM   #1
Bifold doors
Have a 60 inch door opening and wanting to do bifold doors and have only two 30 inch doors. I only see in the home improvement stores 30 in bifold doors which would mean i would have to get two sets to cover the door opening. Can this be done?
optiguy is offline   Reply With Quote
Old 03-26-2012, 11:58 AM   #2
Rewards Points: 12,790
That's the way it's done all the time. You would not want a single 60" bifold, you would never be able to keep it in alignment.
mae-ling (03-28-2012)
Old 03-26-2012, 12:29 PM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
Ditto what Joe said.
We have double sets like that in both bedrooms.
Old 03-26-2012, 04:06 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 996
just keep in mind that a 30" bifold isnt actually 30" they are slightly less, typically by 1/4" or so as they need atleast a 1/4" gap at each side of the door for them to properly operate. hows the height of the opening, as bifolds are also only 79" tall do to allow for the hardware to work.. the height of the opening should be between 1 3/4"- 2" taller than the door so you can get the pivot pins into the track and bracket on the floor
woodworkbykirk is online now   Reply With Quote
Opinions, bypass or bifold doors Michaelpro Windows and Doors 3 03-14-2012 12:00 PM
bifold doors p wade Carpentry 4 07-09-2011 08:47 AM
Ideas for building custom bifold doors? crashley1784 Carpentry 1 02-18-2010 03:49 PM
Help installing bifold doors MT Stringer Carpentry 5 11-05-2008 11:24 PM
