Bifold Doors - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-08-2011, 01:56 PM   #1
bifold doors
Hi. I'm renovating my kitchen. Currently have one pantry door which is 18" x 80". I'm going to take the extra wall space to the right of this pantry and add two more doors, recessing into the laundry room about 10" with about 3" decorative trim between and around the doors to give the whole thing a dressed up look. Home centers need 2-5 wks to deliver doors which are expensive. I would manually build my door jambs, and add hinges. Question: Can I purchase a set of Bi-fold doors and disconnect them so that I have two separated doors? I would not use a standard door handle, but likely use a cabinet handle, with a magnetic catch, or ball and groove kind of hardware. Any input would be greatly appreciated. Thanks.
p wade is offline   Reply With Quote
Old 07-08-2011, 06:56 PM   #2
So am I understanding right that the rough opening will now be 28" wide? So 12" Bifolds could be taken apart and hinged to swing like normal doors. However, I hope you have some good door experience, because what you're talking about doing requires a fairly high skill level if it's going to look and work properly. Other options- pocket door, swing door. Good luck
Stanchek is offline   Reply With Quote
Old 07-08-2011, 11:28 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 188
For some reason I don't understand what you are doing but your question:
The answer to your question is yes you can do that, just remove all the bifold hardware, install the hinges like you would any regular door. You may have to go with a narrower hing as the bifold doors aren't as thick as a regular door.
You may have to cut the length of the sides of the jambs as they will more than likely be too long and the doors will set too high off the floor.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 07-09-2011, 08:25 AM   #4
Rewards Points: 5,336
Yes, you can take apart bifold doors and add hinges to them.
Ron
B. Franklin 1759
Old 07-09-2011, 08:47 AM   #5
Rewards Points: 558
Why not just get a standard door 2' 4" x 6'8" and make your rough opening size 30" x 82 3/4". If money is the issue here you can try your local wood door manufacture someone like this http://www.wood-doors.com/dprehung.html and see if they have any doors your size and check their specials Iím sure you would find something that is not to expensive.
epson is offline   Reply With Quote
installing bifold doors with baseboard molding cuda719 Carpentry 1 07-04-2011 09:15 PM
Ideas for building custom bifold doors? crashley1784 Carpentry 1 02-18-2010 03:49 PM
Bifold doors -- non-standard rough opening michelob Remodeling 5 05-19-2009 12:19 AM
Installing bifold doors in a non-standard rough opening michelob Carpentry 7 05-15-2009 01:35 PM
