Bifold Doors - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-26-2011, 12:20 AM   #1
Question
bifold doors
Does anyone know how to install trackless bifold doors with laminate flooring?
loriel is offline   Reply With Quote
Old 06-26-2011, 01:18 AM   #2
NACE Coating Inspector
mustangmike3789's Avatar
trackless??? no track at the top or bottom?
mustangmike3789 is offline   Reply With Quote
The Following User Says Thank You to mustangmike3789 For This Useful Post:
Willie T (06-26-2011)
Old 06-26-2011, 02:18 AM   #3
I've installed many bi-fold doors ... Cant say i've ever seen much less installed ones without a track
boozehound is offline   Reply With Quote
Old 06-26-2011, 07:10 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 776
Yes, I have installed several trackless bi-fold doors. You hang them just like you do double doors except the two doors that hing from the supporting doors will be hinged backwards to fold against the back of the supporting door when open. Another thing is be sure the top hinges of the supporting doors are secured with maybe longer screws into the framing members as there is some pressure on the top hinges.
I hung triple bi-fold (no track) doors 8 foot tall made from MDF (their choice, not mine), that was an experience, had to use ball bearing hinges and really beef up the framing. It is tough to keep doors that heavy from sagging as they are very heavy.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
loriel (06-26-2011)
Old 06-26-2011, 07:14 AM   #5
Old School
Willie T's Avatar
How are they kept aligned. What keeps them from just swinging out into the room, or back into the closet?
And what would the type of flooring have to do with anything?
Willie T
Old 06-26-2011, 11:51 AM   #6
Thanks for the info Jim, but i was wondering about the pivot that goes into the laminate, as it is a floating floor and was told you can't put weight that moves around on it. I guess everytime you open/close the bifolds it puts pressure on the floor and shifts it some what.
Loriel
Old 06-26-2011, 12:56 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 776
Loriel, there is no pivot on the floor, they are hung just like a regular door, the hinges are on the door jamb just like your front door is.
Willie, we used magnetic catches to hold each door against the door stop and on some I have installed we used the ball catches in the header piece of the jambs. When opening the doors they will swing into the room if you don't fold them up as they are opened. I have seen where the two clips that are used on the bottom back on regular bi-folds, to keep the bottoms aligned, used with this type bi-fold. I never did like them because they rubbed the backs of the doors.
Jim
loriel (06-26-2011)
Old 06-26-2011, 06:36 PM   #8
Thanks Jim.
The Following User Says Thank You to loriel For This Useful Post:
BigJim (06-26-2011)
Old 06-27-2011, 01:21 PM   #9
Weekend Builder
Crackers's Avatar
I tried them.. not impressed.
Trackless seems OK when used outside (fence), or as in a fireplace door, but as a hallway closet they are very large and swing everywhere, sag...
Stay with normal, track on top (IMO)
Crackers is offline   Reply With Quote
Ideas for building custom bifold doors? crashley1784 Carpentry 1 02-18-2010 02:49 PM
Bifold doors -- non-standard rough opening michelob Remodeling 5 05-18-2009 11:19 PM
Installing bifold doors in a non-standard rough opening michelob Carpentry 7 05-15-2009 12:35 PM
Help installing bifold doors MT Stringer Carpentry 5 11-05-2008 10:24 PM
