Bi Fold Doors - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-08-2010, 09:55 AM   #1
bi fold doors
can u put bifold doors on 1 5\8 framed wall
THX
ron08 is offline   Reply With Quote
Old 10-08-2010, 10:04 AM   #2
Rewards Points: 558
Sizing a bi-fold door opening is slightly different than measuring for a standard door. Bi-fold doors require room to fold as they are opened. They also require additional space for the track that the bi-fold door slides on during operation. So to answer your question, no.
epson is offline   Reply With Quote
Old 10-08-2010, 12:23 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 538
Yes you can put bifold doors in a 1 5/8 inch jamb. The doors should be 1 3/8 inch or less thick and the track is not as wide as the doors so you should be good to go.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Willie T (10-08-2010)
Old 10-09-2010, 09:16 AM   #4
Rewards Points: 558
And I thought it couldn’t be done go figure. I stand corrected.
trim for hiding track on bi fold doors ron0805 Carpentry 11 02-15-2010 09:59 AM
Input on which doors to replace interior & exterior door with... tomas21 Carpentry 13 12-08-2009 09:32 AM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 01:37 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 05:04 PM
