Bi Fold Closet Doors - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-20-2011, 02:09 PM   #1
Rewards Points: 107
Bi fold closet doors
I guess I am going to replace all my closet doors with bi fold doors. When I measured the openings today I found they vary from 46 1/2 to 48" wide. My question is: Is a 48" bi fold door 48" wide or is that the rough opening size? I would hate to have to take 1/2 or so off each door. Any other ideas if they don't fit? TIA
thunderhead is offline   Reply With Quote
Old 05-20-2011, 02:26 PM   #2
Old School
Willie T's Avatar
Look on the side of the box at the store. It should have all the information you need.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
thunderhead (05-20-2011)
Old 05-20-2011, 03:03 PM   #3
Tizzer's Avatar
Rewards Points: 460
4 foot bi-folds are right at 48", and are usually 4 panels. When searching around online, the specs. will show actual door size & rough opening size.
I didn't see any 4ft. ones at Lowes but did find these. Didn't see any wooden ones.
http://www.wilmar.com/Sku/86-6914
If these 46" doors are not under a load bearing wall, you could rip out a jack stud to give you 48" if you don't wanna cut doors.
Tizzer is offline   Reply With Quote
Old 05-21-2011, 07:47 AM   #4
A door a day is all I ask
TheDoorGuy's Avatar
Hi Thunder,
The door openings that you have are sized for sliding (bypass) doors.
They are less than 48" so that they will over lap in the center.
The standard size bifold doors that you are considering actually measure about 47 1/4"
when you set them up side by side. They are designed to fit into a 48" finished opening.
You can take the unit apart and plane the doors down evenly but you may have to plug and redrill
the pivot holes if you can't adjust the brackets to move doors closer to the wall side.
The other option, as Tizzer said, is to reframe the rough opening to accept a new finished opening that
is the right side. A bit of a project but doable. You would want to make sure that the header is supported.
Then you would need to make up a jambset that is the correct finish opening size.
I guess the moral of the story is: Trimming bifolds for height is easy...Trimming for width...Not so much!
Good luck with the project!
RC/DG
Richard The Door Guy
www.thedoorguy.com
TheDoorGuy is offline   Reply With Quote
6 panel bypass closet doors Steve Baumgart Carpentry 5 05-10-2013 08:52 PM
Space for hinges on custom closet doors nrk411 Carpentry 3 07-11-2010 07:34 PM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 01:37 PM
Closet Doors for non standard closet dimensions jherschel Carpentry 7 02-22-2008 04:45 PM
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 04:57 PM
