Best Wood Glue For Kitchen Cabinets - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-13-2014, 05:22 PM   #1
DIY-Her's Avatar
Rewards Points: 261
best wood glue for kitchen cabinets
I ordered Conestoga wood cabinets yesterday, and was told to expect delivery by 2/21. What is the best wood glue for this project.
We've put together small type cabinets before that always came with the glue needed.
There are so many brands out there that I don't know if any have advantages over the other.
thanks for your input.
DIY-Her is offline   Reply With Quote
Old 02-13-2014, 06:07 PM   #2
Civil Engineer
Rewards Points: 4,944
I am not familiar with Conestoga. What exactly do you need to glue to prepare the cabinets? For general gluing in a dry environment (indoors), I usually use yellow glue (known as aliphatic glue). There are numerous manufacturers, Elmers makes it, Titebond makes it (that is the one I use). But aliphatic only works well on wood, it is not suitable for plastic or laminate.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
DIY-Her (02-13-2014)
Old 02-13-2014, 06:22 PM   #3
DIY-Her's Avatar
Rewards Points: 261
they are all wood plywood boxes and solid wood front frames and doors.
http://www.conestogawood.com/
They are put together with splines to hold them while the glue dries.
http://youtu.be/S6zfX264rq8
Old 02-13-2014, 07:03 PM   #4
chitownken's Avatar
Rewards Points: 510
I prefer Titebond II for cabinetry and furniture.
chitownken is offline   Reply With Quote
The Following 2 Users Say Thank You to chitownken For This Useful Post:
DIY-Her (02-13-2014), joecaption (02-13-2014)
Old 02-13-2014, 08:46 PM   #5
DIY-Her's Avatar
Rewards Points: 261
thanks. I just found their Facebook page and saw a video of the difference between II and III. They said III gives you a bit more time to make adjustments before the glue dries up fast?
Old 02-13-2014, 09:15 PM   #6
Rewards Points: 960
The original Titebond is fine.
cleveman is offline   Reply With Quote
Old 02-13-2014, 09:23 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 792
I like the Elmers wood glue (yellow) it never failed me over all the years I use it. Titebond II is good glue and is used for inside applications, Titebond III is water proof where the II is just water resistant.
I bought a 5 gallon bucket of a wood glue I hadn't heard of years back and it taught me a valuable lesson, stick with what you know works, if it ain't broke don't fix it. We were building hospital couches, the sides were 1 1/2 inch thick butcher block red oak, with the off brand glue, several of the sides fell apart before they left the shop.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
DIY-Her (02-14-2014)
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Which Is Better - Wood Glue OR Liquid Nails? JackOfAllTrades Carpentry 10 09-16-2009 02:02 PM
Do you wanna buy the wood kicthen cabinets from China? Dwyane Wade.cn Building & Construction 3 08-13-2009 07:56 AM
when painting wood trim and cabinets oldrivers Painting 3 07-15-2009 04:13 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
