Best Wood For Exterior Fence Gate - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-28-2007, 03:26 PM   #1
Rewards Points: 682
best wood for exterior fence gate
What is an adequate wood for exterior fence gate? I am looking at Lowes and HD, there seems to be many choices.
I'm looking for 2X4s and the flat pieces too.
darsunt is offline   Reply With Quote
Old 11-29-2007, 08:01 AM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
What is the rest of the fence made of? I would say match what you have. If you do not care about match, and you can only shop at HD or Lowes then your choices are limited.
Pressure Treated Southern Yellow pine (The green or brown stuff)
or
Cedar
The cedar that those two stores sells is, around here, knotty western red cedar. The lowest grade. You CAN get this stuff w/o knots (or very few) at other places and its beautiful.
Other choices from other places.
Ipe, Mahogany, White Cedar, Cypress, Teak, White Oak (NOT red Oak), and maybe others.
Brik is offline   Reply With Quote
Old 11-29-2007, 08:38 AM   #3
Rewards Points: 150
If it's gonna be painted, get pressure-treated wood. Be sure to use hardware rated for use with it. Sand it smooth, then, a coat or two of exterior primer/sealer and a couple coats of exterior paint.
If it'll be stained, I would consider going to a lumberyard. Check out red cedar, ipe, or white oak. Teak and mahogany are on the expensive side. Whatever wood you choose, you probably want to use something like Cabot for finish.
scorrpio is offline   Reply With Quote
Old 12-02-2007, 08:53 PM   #4
remodeling pro
Unfortunately all the choices you see at them are bad ones. By that I mean that the materials are poor quality. Their cedar fence boards are a low grade full of knots and extremely thin compared to a quality fence board, and their treatded material is so laden with water from the teatment process that it will warp like crazy as it dries. If you do not have a local fence company who will sell you materials, you should be able to buy 1 x 6 clear grade western red cedar at a decent lumber yard, and easily cut the "dog ears" with a circular saw or miter saw. If you are matching to an existing fence, cedar is most likely what you have. If you do not have to worry about the texture match and want to spend a few $$ dollars more, step up to clear heart redwood, this is the Cadillac of exterior wood.
You are not talking about a large quantity of materials for a gate, so I would go for top quality materials, Including fasteners of stainless steel or a quality coated deck screw.
Pressure treated boards are strictly low end IMO. They are pine, full of knots, and will warp like crazy when they dry out.
troubleseeker is offline   Reply With Quote
Old 12-03-2007, 08:36 PM   #5
bofusmosby's Avatar
Somwthing wlse to consider about P.T. wood. You'll have to let it weather for a number of months before it will hold paint.
bofusmosby is offline   Reply With Quote
Old 12-04-2007, 11:42 AM   #6
Rewards Points: 1,088
Personally, I would go with cedar if you're willing to take care of it. If not, then there's always composite fencing. Gone are the days when ugly white was the only option.
handy man88 is offline   Reply With Quote
Old 07-01-2008, 12:04 PM   #7
Composite Fence
I am considering the composite fence by Lowes because it is not shiny and plastic looking (vinyl fencing) and it does not need to be maintained. I know that there is not a lot of information on it and there are not many options but I am going to try it. Any experience, anyone?
Kate01776 is offline   Reply With Quote
Old 07-01-2008, 12:10 PM   #8
Yes, I would go with the composite fence, but it's heavy and expensive. Over time though, you will need to wash it with a deck cleaner & pressure washer to remove mold, mildew, moss, and fungus.
Old 07-05-2008, 10:48 AM   #9
your best gate will be custom rod iron ...with the family crest in the middle.
anything else says I can't afford that.
Big Bob is offline   Reply With Quote
Old 07-05-2008, 11:21 AM   #10
BUILDER / REMODELING CONT
buletbob's Avatar
Well put I agree!
Old 07-07-2008, 09:21 AM   #11
Licensed Contractor
When forced to build gates, I always lean toward cedar. It is relatively stable, rot resistant, and primes/paints well. And it's relatively light, which is easy on your hardware.
I resist the urge to use treated lumber, as it is wet, heavy, and prone to checking and warping/cupping as it dries. And you need to let it dry out a few months prior to finishing.
Renovator,LLC is offline   Reply With Quote
Old 07-07-2008, 11:08 AM   #12
<snip> If you do not have to worry about the texture match and want to spend a few $$ dollars more, step up to clear heart redwood, this is the Cadillac of exterior wood. <snip>
Yep, clear heart redwood USED TO BE the Cadillac of exterior wood, but that was back when we had decent-quality "old growth" redwood available. Its growth rings were around a thirty-second to maybe a sixteenth of an inch apart. That's what gave redwood its reputation. Nowadays, the fast-grown highly porous "redwood", what they call "Second-Growth" redwood, has little if any rot resistance. That's not just my opinion, it's a fact you can see in the Wood Handbook published by the U. S. Forest Products Laboratory, and available over the Internet. When I need to use that grade of redwood, I find that soaking it in that penetrating epoxy makes a big difference in how well it stands up to weather.
Read the Wood Handbook carefully....particularly the first few chapters, which discuss mostly all the different kinds of wood, imported and domestic, hardwoods and softwoods, and compares their rot resistances. It is a valuable resource and you can download it for free, or buy your own bound copy. I personally like to have a book on the shelf I can pick up and read when I want to.
Pro Painter is offline   Reply With Quote
Old 07-10-2008, 12:27 PM   #13
Rewards Points: 682
Next gate I'll probably use clear cedar for 2 X 6. But that stuff isn't all heartwood, correct? So it doesn't resist decay that well?
By the way, do they have PT 2 X 2s and 6 X 2s? I didn't notice any last time I was at the lumberyard.
Old 07-10-2008, 01:24 PM   #14
AYC (Alaskan Yellow Cedar) HEARTWOOD has high natural rot resistance. However, the SAPWOOD will rot so fast it will make your head spin.
Deal with an established and reputable lumber dealer who knows what he is selling, and make sure you know what you are getting.
Old 10-17-2011, 06:15 PM   #15
Hi, I'm in the same boat. I need to make two gates for the side of my house. I just put up a six foot block wall that I had originally intended to attach the gates to. But I've been getting advice that it would be wiser to attach the gates to the front and back corners of my house on the reenforced studs. This mainly because I wanted to use the composite fence materials sold at Lowe's with one of the "Adjust-A- Gate" steel frame kits for strength. But I've come to find out the whole thing with hardware and composite will weigh about 105 lbs. So now I'm worried the house or wall will not support this kind of weight. Now I'm thinking of wood for the weight issues. Anybody want to throw in any opinions on these issues. Thanks, Jeff
jawz1968 is offline   Reply With Quote
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 03:29 PM
Repairing the wood for painting bofusmosby Painting 4 06-16-2007 11:55 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 04:16 PM
