Best Wood Choices For Painted Stair Risers? - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-22-2013, 04:13 PM   #1
Rewards Points: 27
Best wood choices for painted stair risers?
What are the best woods for 3/4" risers that will be painted white? Using them with stained oak treads. I am thinking... poplar. Price not important. Looks and durability from dents and dings from normal usage is important.
Thanks for opinions.
hkeiner is offline   Reply With Quote
Old 04-22-2013, 05:13 PM   #2
Rewards Points: 196
Poplar is a good choice to be painted but its almost as soft as pine so it will dent.
Jason34 is offline   Reply With Quote
Old 04-22-2013, 06:08 PM   #3
Roofmaster
Rewards Points: 2,210
Not many people kick their toes into the risers as far as I know. Poplar is probably fine. Even pine should be OK.
Old 04-22-2013, 06:08 PM   #4
Rewards Points: 27
Maple a better choice?
Old 04-22-2013, 07:34 PM   #5
DIY staff
Rewards Points: 7,174
Hard or soft maple is a good choice also----in this area paint grade hard maple is reasonably priced---
Poplar is used most often for paint grade risers---with no problems---
woodworkbykirk (04-22-2013)
Old 04-22-2013, 07:46 PM   #6
Rewards Points: 27
A another related question...
If I go with poplar as the wood, any good reason to buy pre-fabricated risers from a stair parts store online (typically constructed from multiple edge glued staves) rather than just buying 7 1/4" wide poplar boards from a local lumber yard (typically cut from a single piece of poplar)? The risers need to be only about 7" wide (space between the top of one tread and the bottom of the tread above) so I would not expect I would benefit much from using edge glued boards to avoid cupping and warping, unlike the benefit they provide with wider stair treads.
Thought I would ask before installing risers made from poplar boards from a local lumber yard and later finding that I made a big mistake.
Old 04-22-2013, 07:49 PM   #7
Stairguy
Millertyme's Avatar
Rewards Points: 508
Solid poplar risers are good, no need for premade risers
Millertyme is offline   Reply With Quote
Old 04-22-2013, 07:50 PM   #8
DIY staff
I prefer solid wood over the glue ups, whenever possible----often the glue joints show up after a couple of seasons .
Old 04-22-2013, 07:52 PM   #9
Stairguy
Millertyme's Avatar
Rewards Points: 508
Not to mention the might be finger jointed,aka garbage
The Following 2 Users Say Thank You to Millertyme For This Useful Post:
oh'mike (04-22-2013), woodworkbykirk (04-22-2013)
Old 04-22-2013, 07:55 PM   #10
Rewards Points: 27
Seems like there should be no worries using solid piece 7 1/4" poplar boards (from my local lumber yard) for the painted risers.
Thanks for the quick replies and opinions guys.
Old 04-22-2013, 07:59 PM   #11
funfool's Avatar
Rewards Points: 534
why not mdf for paint grade? Is already compressed and should not ding, is easy to work with and will paint nicely.
funfool is offline   Reply With Quote
Old 04-22-2013, 08:27 PM   #12
chitownken's Avatar
Rewards Points: 510
If you use the 7" boards, paint all sides before you put them up. Less likely to have moisture caused warping issues that way.
chitownken is offline   Reply With Quote
Old 04-22-2013, 08:49 PM   #13
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
how will mdf warp on stairs if its for an interior stair. mdf and poplar will both work find. poplar is commonly used for high end homes with paint grade trim. its cheaper than maple or birch but holds up better than mdf
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Old 04-22-2013, 09:32 PM   #14
Rewards Points: 27
I don't have any experience installing mdf myself, but I have seen MDF trim sitting on the shelf at home depot and such that is chipped and damaged from rough handling.
The risers will be installed on a stairway that is open on one end and the risers will be mitered to a stair bracket at this end. I am most concerned about the mitered corners holding up to abuse. I only have 9 steps so the difference in cost between MDF and poplar is marginal to me, especially when compared to the cost of the whole project. I am looking for the best choice of wood/material, not the best value or cheapest.
Old 04-22-2013, 09:34 PM   #15
Rewards Points: 27
Thanks for that tip. I wouldn't have thought of that on my own.
Stair treads - wood choice tradeoffs? kidtire Flooring 0 02-01-2012 05:15 PM
Is this normal??? Exposed wood near foundation of house? simiesue Building & Construction 19 01-04-2012 10:01 PM
Stair Tread and Risers tuchodi Flooring 0 08-03-2011 08:38 AM
Wood Finish to Stair Rails propilot5000 Painting 1 01-09-2007 06:22 PM
Wood stair covering...pergo? DK75 Carpentry 6 11-02-2006 10:51 PM
