-   -   Best wood choices for painted stair risers? (http://www.diychatroom.com/f14/best-wood-choices-painted-stair-risers-177845/)
hkeiner 04-22-2013 04:13 PM
What are the best woods for 3/4" risers that will be painted white? Using them with stained oak treads. I am thinking... poplar. Price not important. Looks and durability from dents and dings from normal usage is important.
Thanks for opinions.
Jason34 04-22-2013 05:13 PM
Poplar is a good choice to be painted but its almost as soft as pine so it will dent.
jagans 04-22-2013 06:08 PM
Not many people kick their toes into the risers as far as I know. Poplar is probably fine. Even pine should be OK.
hkeiner 04-22-2013 06:08 PM
Maple a better choice?
oh'mike 04-22-2013 07:34 PM
Hard or soft maple is a good choice also----in this area paint grade hard maple is reasonably priced---
Poplar is used most often for paint grade risers---with no problems---
hkeiner 04-22-2013 07:46 PM
A another related question...
If I go with poplar as the wood, any good reason to buy pre-fabricated risers from a stair parts store online (typically constructed from multiple edge glued staves) rather than just buying 7 1/4" wide poplar boards from a local lumber yard (typically cut from a single piece of poplar)? The risers need to be only about 7" wide (space between the top of one tread and the bottom of the tread above) so I would not expect I would benefit much from using edge glued boards to avoid cupping and warping, unlike the benefit they provide with wider stair treads.
Thought I would ask before installing risers made from poplar boards from a local lumber yard and later finding that I made a big mistake.
Millertyme 04-22-2013 07:49 PM
Solid poplar risers are good, no need for premade risers
oh'mike 04-22-2013 07:50 PM
I prefer solid wood over the glue ups, whenever possible----often the glue joints show up after a couple of seasons .
Millertyme 04-22-2013 07:52 PM
Not to mention the might be finger jointed,aka garbage
hkeiner 04-22-2013 07:55 PM
Seems like there should be no worries using solid piece 7 1/4" poplar boards (from my local lumber yard) for the painted risers.
Thanks for the quick replies and opinions guys.
funfool 04-22-2013 07:59 PM
why not mdf for paint grade? Is already compressed and should not ding, is easy to work with and will paint nicely.
chitownken 04-22-2013 08:27 PM
If you use the 7" boards, paint all sides before you put them up. Less likely to have moisture caused warping issues that way.
woodworkbykirk 04-22-2013 08:49 PM
how will mdf warp on stairs if its for an interior stair. mdf and poplar will both work find. poplar is commonly used for high end homes with paint grade trim. its cheaper than maple or birch but holds up better than mdf
hkeiner 04-22-2013 09:32 PM
I don't have any experience installing mdf myself, but I have seen MDF trim sitting on the shelf at home depot and such that is chipped and damaged from rough handling.
The risers will be installed on a stairway that is open on one end and the risers will be mitered to a stair bracket at this end. I am most concerned about the mitered corners holding up to abuse. I only have 9 steps so the difference in cost between MDF and poplar is marginal to me, especially when compared to the cost of the whole project. I am looking for the best choice of wood/material, not the best value or cheapest.
hkeiner 04-22-2013 09:34 PM
Thanks for that tip. I wouldn't have thought of that on my own.
