Best Way To Trim Out For Vanity - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-08-2014, 09:22 AM   #1
Rewards Points: 145
Best way to trim out for vanity
How are you supposed to do baseboards for these types of vanities? I installed a smaller one in front of the baseboards and I couldn't get the sink flush with the wall- used a granite backsplash to cover the gap.
Is the best way to notch out the baseboards after installing them to get the legs flush with the wall? Baseboards will be 1x6 with cap molding.
Thanks.
kjmass1 is offline   Reply With Quote
Old 07-08-2014, 10:46 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
fit the vanity in place first without hooking it up, mark the inside position of the legs then pull it away measure the length of the baseboard peices then actually install the vanity. once in place then install the rest of the baseboard by butting into the legs
woodworkbykirk is online now   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
BigJim (07-09-2014)
Old 07-09-2014, 12:51 AM   #3
Rewards Points: 744
I did mine, as you first described.
Seattle2k is offline   Reply With Quote
Old Flooring and Trim Identification and Refinishing BungalowBaby Flooring 8 07-02-2011 07:17 PM
Sheetrock put on w/o removing door trim Carla33 Carpentry 13 12-26-2009 02:32 AM
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 02:19 PM
Painting fireplace & trim? bltwa Interior Decorating 4 03-08-2009 03:57 AM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 01:16 PM
