Best Way To Refinish Trunk Exterior - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-26-2012, 01:38 PM   #1
Rewards Points: 147
best way to refinish trunk exterior
I was cleaning out our garage and found an old wood trunk. not antique, but older. looks cedar lined and in good shape inside. exterior has some light mold and looks like it was been (re)finished more than once...not sure....I am very novice when it comes to woodworking/finishing.
anyhow, my wife asked me if I could refinish the exterior. what is the best way to strip off whats there? like a chemical "peel?" or just sand it down?
I would like to get it back to its original finish and then put a light protective stain on it.
photo attached.
any thoughts are appreciated. happy holidays.
THB
best way to refinish trunk exterior-township-15-huntersville-20121216-00275.jpg
tarheelblue is offline   Reply With Quote
Old 12-30-2012, 09:13 AM   #2
Rewards Points: 722
Do not sand. Use stripper. The stripper that does not have to be neutralized later is easiest to use. Read the instruction and work in well ventilated place. Taking time, using soft scrapers such as plastic and brass brush, and removing by multiple tries will get you to bare wood. Peel off stripper is effective but not worth the price in your case.
Sanding the bare result is your judgement. If you decide that some spots have to be repaired by sanding, don't like the original stain, etc, you will have to sand the whole thing, but the result is usually worse than keeping the original. Your wife will be deciding, of course.
carpdad is offline   Reply With Quote
Old 12-30-2012, 10:10 PM   #3
Missouri Bound's Avatar
Do you know the history of that trunk? Do you know for certain it is not old enough to be an antique? I would take it to an antique dealer and get it appraised before I did anything to it.....mold and all. You would be surprised that what people consider junk is often antique quality. Trust me, I have been collecting antiques for several years and I still get surprised by what I find. Any dates or names on this trunk?
Do you want it your way or the right way?
2004 IMPALA Trunk LEAKING! Need help! LordX Automotive Repairs 11 09-11-2015 05:29 AM
Exterior Paint for Trimwork cityslicker Painting 14 08-03-2012 03:34 PM
How to drywall wall with HVAC trunk and pipe penetrations daphilli Drywall & Plaster 3 09-27-2010 02:15 AM
Help with gas pack trunk sizing justinNC HVAC 3 10-31-2009 08:38 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
