Best Way To Make Shims - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-23-2009, 12:31 AM   #1
CAD
Best way to make shims
Hi, I have a quick simple question - What is the best way to make shims for 2x4 stud walls? The shims need to be around 1/4" thick. Would a table saw be the best tool for this job? I've been thinking about buying one anyway so this is my excuse
CAD is offline   Reply With Quote
Old 12-23-2009, 01:16 AM   #2
"Beam me up, Scottie"
Kevin M.'s Avatar
Rewards Points: 150
You can buy lath in bundles. Normally, it's crappy wood full of knots and cracks. Sheet rock shims may work, they measure 1/8 shy X 1- 1/2 X 36. and resemble brown cardboard. Menards sells them over by the sheet rock.
You can buy a 4 X 8 sheet of 1/4 "OSB and rip 1-1/2" strips on your proposed new table saw. Or, you can rip 1/4 " strips off 2 X 4's on your proposed new table saw.
decisions, decisions!!!!!!!
Kevin
Kevin M. is offline   Reply With Quote
Old 12-23-2009, 04:11 AM   #3
Remodeling Contractor
They sell shims in various thicknesses that are 8 foot long specifically for this use. These are called drywall shims. Making your own is not cost effective.
Old 12-23-2009, 04:20 AM   #4
Too Short? Cut it Again!
However, if you have lots of work to do on your house, a good quality table saw will come in very handy. I cheap, unstable one could hurt you.
Old 12-23-2009, 05:11 AM   #5
Kevin M.'s Avatar
Rewards Points: 150
Bob,
Where do you buy 8' drywall shims in various thicknesses?
KK
Old 12-23-2009, 05:13 AM   #6
Originally Posted by Kevin M. View Post
Bob,
KK
From drywall suppliers. Or online at www.trim-tex.com
Old 12-23-2009, 05:34 AM   #7
Kevin M.'s Avatar
Rewards Points: 150
Thanks for the info. We have a new drywall supplier locally, maybe they have them.
Kevin
Old 12-23-2009, 07:16 AM   #8
Mold!! Let's kill it!
Rewards Points: 2,012
Yep....... a table saw is the best. You can make high quality shims of any thickness.......... especially at Christmas time. And after the shims, you'll still own a tool with lots more uses after Christmas. Tell your significant other that you read it right here in black and white.
Old 12-25-2009, 10:24 PM   #9
Rewards Points: 85
CAD,
Look at this video for making shims with a table saw,
http://www.finehomebuilding.com/item...r-the-tablesaw
Best of luck with the projects, rredogg
rredogg is offline   Reply With Quote
Old 12-26-2009, 01:25 AM   #10
once you have the shim length desired. Make a jig and you can cut precise shims without wasting time.
carpenter377 is offline   Reply With Quote
FREE plans/instructions for easy to make Magic Box! DangerMouse General DIY Discussions 5 07-23-2009 04:14 PM
Want to make cuts in cabinet walls to put in shelfs humberguy Carpentry 3 07-09-2009 09:07 PM
how to make white mortar for brick wall nhertel Building & Construction 2 05-26-2009 08:22 AM
Need to make bases for porch columns rafaell General DIY Discussions 3 09-01-2008 09:32 PM
Anyone know how to make cafe doors? versatile1 Carpentry 3 08-01-2008 09:39 PM
