best way to keep 2 boards perpendicular?
Get a 4x8 sheet of OSB or plywood.
Clamp one board to one edge....clamp the board to the adjacent edge.....if the boards are aligned to the edges....that is about as much of a 90 as you can get.
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
