-   -   best way to keep 2 boards perpendicular? (http://www.diychatroom.com/f14/best-way-keep-2-boards-perpendicular-166910/)
echobravo 12-19-2012 03:29 PM
its difficult for me to explain what im trying to do
so ill just ask in simple terms,
i need to attached 2 boards with 1 being perpendicular to the other
like an "L" shape.
what is the best and simplest way to keep the them 90 degrees, even and leveled while i drill some screws to hold it together.
im guessing clamps and a carpenter square?
joecaption 12-19-2012 03:48 PM
Going to have to do better then that.
What is it your really trying to do?
Google Greg tool.
carpdad 12-19-2012 05:25 PM
Lay them down on the edge and you can approximate the angle against a square inside or outside. It will not stay square. You need some kind of brace.
jagans 12-19-2012 05:47 PM
Yes, What is the end game?
ddawg16 12-19-2012 06:51 PM
Get a 4x8 sheet of OSB or plywood.
Clamp one board to one edge....clamp the board to the adjacent edge.....if the boards are aligned to the edges....that is about as much of a 90 as you can get.
echobravo 12-19-2012 08:40 PM
ok ill try to explain as best as i can...
im remodeling a bed room, im going to build a cabinet door into the wall to house a computer tower.
the shelf thats going to hold the tower, i plan on attaching it to the door so when you open the door the tower is exposed (like and L)
its going to pivot on a lazy susan turn table to open. so i need it to be level
im wanting to do this the best way so its sturdy and dont fall apart
SeniorSitizen 12-19-2012 11:03 PM
1 Attachment(s)
This may or may not fit your application, but to hold a cabinet square for assembly a pair of squaring boards can be used. These are made so the clamps can act as 8 more hands.
Seattle2k 12-20-2012 02:00 AM
Google Greg tool.
Do you mean Kreg Tool/Jig?
ddawg16 12-20-2012 06:53 AM
Fairview....I like your idea....it looks like you made those out of 1/2" cabinet grade plywood?
Echo....Fairview's idea is good...but if you don't have the equipment to make what he has...you could buy a couple of these...
http://images.rockler.com/rockler/im...190-14-200.jpg
http://www.rockler.com/product.cfm?p...3&site=ROCKLER
echobravo 12-20-2012 07:53 AM
thanks for the feed back all :thumbsup:
SeniorSitizen 12-20-2012 08:32 AM
Thanks, but I can't take the credit for that idea. I just saved that pic from long ago because I thought it was a great plan for larger awkward items. I just regret I didn't save the information to give credit.
