Best Way To Fix A Cracked Step? - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-22-2011, 12:59 PM   #1
Best way to fix a cracked step?
I have a staircase that is carpeted and the wood underneath it on the first step (the part you put your foot on) is cracked and squeaky when you step on it. I'm no good with carpentry, but I was looking for some advice on the best way to fix it and/or easiest. I couldn't find any threads on this so I thought I'd ask.
Thanks guys!
Drywallhelp is offline   Reply With Quote
Old 07-22-2011, 07:17 PM   #2
DIY staff
Rewards Points: 7,174
A picture would help----Glue --Tight Bond or Elmers carpenter glue might work--
A picture will help.
Old 07-22-2011, 10:02 PM   #3
kwikfishron's Avatar
Rewards Points: 1,004
Thanks guys!
You said “easiest“… You could try to running a couple of trim head screws through the carpet into the tread and stringer.
I’ve done this many times to quiet a squeak. Sometimes it works, sometimes it doesn’t but it’s worth a try if you don’t want to tear things apart.
kwikfishron is online now   Reply With Quote
Old 07-22-2011, 11:39 PM   #4
That sounds like its worth a shot. You'll have to forgive me, I tried looking up what tread and stringer is and I'm not really sure where the screws would go. Could you be kind enough to explain that? Thanks!
Old 07-23-2011, 06:57 AM   #5
The treads are what you walk on the stringers are the framing the treads are attached to.
As mentioned post a picture of what you have.
Some stairs in older houses used oak for both treads and stringers. Oak is extremely hard and would make the screw trick more difficult.
Old 07-23-2011, 07:01 AM   #6
DIY staff
Simple stair part definitions:
Tread--the part you walk on--also called a step.
Stringer---the zig zag shaped piece of wood on either side of a staircase that the treads sit on (or in)
Open stringer--simplest type--2x12"" board cut for the treads and risers --treads and risers simply glued and nailed---basement stairs are almost always this type.
Closed stringer----This is a more complicated stair---there are grooves cut into the sides of the stringer using a router----the treads and risers are slipped into the grooves from below and held in place with wood wedges and glue.
Tightening up a staircase like this must be done from the underside of the staircase.
Risers: the upright piece of wood between the treads---you kick this with your toe if you are clumsy.
Hang drywall vertical or horizontal nickm1024cobra Drywall & Plaster 54 03-30-2011 11:37 AM
Broken Roof Truss chris0914 Building & Construction 6 11-24-2010 11:59 PM
Unfinished step around wood laminate floors markq Flooring 7 07-17-2009 07:19 PM
tiling outdoor step kristinmcdonald Tiling, ceramics, marble 6 06-08-2009 11:02 PM
Step footing has gaps joshoc Building & Construction 4 05-06-2009 04:11 PM
