Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 04-04-2010, 12:26 PM   #1
dIYHell
Best way to fill when using clear coat only.
I am trimming out 4x4 columns by ripping pieces of left over Cedar Siding I have. After I am done I plan on putting a clear seal on them. I am not a proffesional finish carpenter so I have a some small gaps in where they meet, whats the best way to fill that to make it look good. I see I can get that colored putty to match but its not sandable. would rather beable to fill , sand and seal. Also is the colored putty ok for external use?
rocketdoctor is offline   Reply With Quote
Old 04-04-2010, 01:27 PM   #2
Remodeling Contractor
sanding putty is not the way to go, since the putty and the wood will not accept the finish the same way. Thus the putty shows too much. Matching a finishing putty that is simply filled with a putty knife to the finished job is the correct way.
Old 04-04-2010, 02:04 PM   #3
dIYHell
If I am just putting a clear polyurethane or sealer on the wood do I fill with the putty before or after.
Old 04-04-2010, 02:54 PM   #4
Moderator
kwikfishron's Avatar
You might add another thin piece of trim like 1/4" x 1" to make little cedar corners to cover the gaps and give it a little more detail.
kwikfishron is offline   Reply With Quote
Old 04-04-2010, 03:15 PM   #5
fill after
Laminate Counter Tops, clear coat? joedreamliner787 Painting 9 06-16-2011 04:55 PM
Clear coat a fence to help with graffiti cleanup? Crytot Painting 2 05-04-2009 01:41 PM
clear coat Bob416 Painting 2 02-27-2009 06:04 PM
clear coat over 100% Acrylic Latex cabinets Jolly Roger Painting 2 08-26-2008 08:18 PM
What to look for in a clear satin coat product joeyboy Painting 16 08-09-2007 05:09 PM
