Best Way To Fasten A Top Plate To An I Beam? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-22-2009, 10:47 PM   #16
If the I Beam is going to be within the ceiling or wall, I would make the wall tight use PL... and Pre-drill and use self-tapping screws. You don't need alot just a few screws (one ever 14"OC). If the I Beam will be visible, Box it out as described before and attach wall as usual
OutToPasture is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 09:46 PM
