Best Way To Fasten A Top Plate To An I Beam? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-21-2009, 10:52 AM   #1
Best way to fasten a top plate to an I beam?
Hi there,
I'm refinishing a basement and would like to run a wall directly under the single I-beam we have in the basement (to encapsulate the posts and split the room).
Is there a recommended way to fasten the top plate to the I beam? Bolting it on seems like an obvious potential, but i didn't want to just start drilling holes into the beam.
Thanks for your input!
Bob
jcims is offline   Reply With Quote
Old 03-21-2009, 11:49 AM   #2
Drywall contractor
Rewards Points: 1,070
Shoot it with a powder actuated tool (Ramset).
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-21-2009, 11:54 AM   #3
Remodeling Contractor
If you don't have one or can't rent one than just make the wall tight and attach with PL400 glue.
Old 03-21-2009, 12:29 PM   #4
Really? That's crazy.
Will take a look at that vs the glue. Thanks folks!
Old 03-21-2009, 01:13 PM   #5
motivator
Speedball's Avatar
Nail guns.....er....powder actuated fastening devices are great.
............Enjoy...Pat
Speedball is offline   Reply With Quote
Old 03-21-2009, 01:27 PM   #6
It was not crazy.. it is the way any pro would do it. My suggestion was more for a DIYer without all the tools. These nail guns will shoot a steel nail though steel very easily.
Old 03-21-2009, 04:13 PM   #7
Old School
Willie T's Avatar
Yes, I guess it does sound a little crazy. But it's true. A ramset is the preferred method of attachment.... and it is quick and super easy. You just squeeze the trigger, and it's done.
Willie T
Old 03-21-2009, 08:08 PM   #8
Hope my comment didn't come across wrong...I believed you guys, just never would have though that would work. Checked at HD on the way home and sure enough, their powerset kits showed steel up to 3/8" thick. I grabbed some glue for tonight because the only gun that ran the 'power level 5' blanks (what they suggested on the back of the box for steel) was $200. Will check the rental place tomorrow.
Thanks again folks!
Old 03-21-2009, 10:19 PM   #9
Drywall contractor
Understand your skepticism. The rental route would be the best option if you can't borrow one. Couldn't really venture a guess as to how much and if it would be worth it by the time you buy shot and pins....
Bob's suggestion may well be the best in the long run. Just be sure to allow enough time for the glue to set before you hang any drywall. (Maybe even add a couple of bolts, just for good measure.)
Old 03-21-2009, 10:49 PM   #10
are you sheetrocking all three sides of that I beam? If so another option for you is to build a ladder on both sides of the I beam flush with the bottom of the I beam or 1 1/2" lower. If its flush, you can add on with screws and some PL400 3/4" plywood to the bottom ( saves on hieght) or if you go the 1 1/2" lower, then just add some 2X4"s across from side to side and add your wall to that after you sheetrock it. ( Will save time later on )
To build a ladder, just take a 2X4 and rip it half. Now attach your 2X4 cripples to whatever the height is on flat. Real easy. Build it on your work horses or the floor then nail or screw it off to the floor joist above. Give yourself a little playroom left to right.
II Weeks is offline   Reply With Quote
Old 03-22-2009, 09:49 AM   #11
heres another option and its what we do if the I beam is less than 10" high.
Join these to every other joist and again, the bottom can be either 2X4's or ply wood.
Old 03-22-2009, 11:56 AM   #12
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Weeks, I'm impressed with your illustrations. How do you do it?
Maybe Sketch Up? + something else? The screws look photo quality.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-22-2009, 12:03 PM   #13
lol
its MS paint and the screws are copy and pasted
Old 03-22-2009, 01:00 PM   #14
Tool Geek
PaliBob's Avatar
Congratulations Weeks,
MS Paint is surprisingly powerful.
You know how to use all the tools including copy,cut, & paste.
I've never tried any drawings as complex as yours in MS Paint.
Good Work
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-22-2009, 03:42 PM   #15
Cut: use the edit menu or in any Windows app Ctrl+X
Copy: Ctrl+C
Paste:Ctrl+V
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 09:46 PM
