Best Way To Cut Thick Caulk? - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-30-2011, 11:02 PM   #1
Rewards Points: 107
Best way to cut thick caulk?
Looks like I will be removing the new replacement windows that a hack installed for me last year. This was the worst job I have ever seen, this guy claims to have been doing carpentry for 40 years! I would not be surprised if I find that the only thing holding the windows in is the caulk. Anyway, my question is: What is the easiest way to cut caulk, remember this is about 4" thick. I know I will run a sawsall to cut any screws that he may have put in by accident. TIA
thunderhead is offline   Reply With Quote
Old 05-30-2011, 11:23 PM   #2
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 690
4" thick?
WirelessG is offline   Reply With Quote
Old 05-30-2011, 11:27 PM   #3
Rewards Points: 107
Maybe I should have said deep? They are replacement windows and he filled the sides, top and bottom with caulk.
Old 05-31-2011, 07:05 AM   #4
Rewards Points: 1,532
Recipt saw should cut through it I'd think.
bob22 is offline   Reply With Quote
Old 05-31-2011, 07:28 PM   #5
Custom Home Builder
How many cases of caulk did he use??
thomasjmarino is offline   Reply With Quote
Old 05-31-2011, 08:11 PM   #6
DIY staff
Rewards Points: 7,174
You will find that a large Painters tool is going to be handy.
Sharpen it up like a chisel and keep it handy.---Mike---
Old 05-31-2011, 09:34 PM   #7
Originally Posted by WirelessG
4" thick?
It probably hasn't even dried yet.
Painters tool & snap-off utility knife.
Craftsman Jay is offline   Reply With Quote
Old 06-01-2011, 01:55 AM   #8
timthetoolman
Are you sure this isn't spray foam insulation? 4" deep of caulk? This would get really expensive.
timthetoolman is offline   Reply With Quote
Old 06-01-2011, 08:34 AM   #9
Rewards Points: 5,336
The window should be around 3 1/2" thick. Why would you think the caulk is 4". Did you see him with dozens of cases of caulk or is this an assumption on your part that's how he filled the gaps?
Post some photos of a few windows.
Ron
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 36 02-24-2016 03:01 PM
How to Clean Up Caulk Mess on Driveway Left By Construction Crew ToolbeltGal Building & Construction 6 09-25-2010 05:36 PM
Best Bathroom Caulk for 2010? SimpleJack Plumbing 9 04-01-2010 05:12 PM
Caulk Frustration j4ino Building & Construction 5 09-29-2008 08:03 AM
recaulking: cleaning out old caulk questions adamc Painting 6 09-19-2008 06:30 PM
