Best Way To Clean Dust Off Surface Being Refinished? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-15-2012, 02:05 AM   #1
Rewards Points: 682
Best way to clean dust off surface being refinished?
I am planning to sand and refinish some wood and furniture. What is the best way to remove the dust after sanding? Dry wipe down with paper towel good enough, or is more necessary? Like wiping down with a wet cloth?
darsunt is offline   Reply With Quote
Old 03-15-2012, 06:47 AM   #2
kwikfishron's Avatar
Rewards Points: 86
I blow off as much as I can then wipe it down with a lacquer thinner soaked rag.
Don’t use water!!! Depending on what you’re working with, water can raise the grain of the wood and you’ll have to sand it all over again
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
user1007 (03-15-2012)
Old 03-15-2012, 06:58 AM   #3
Stay-at-home GC
Tack cloth too
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 03-15-2012, 07:10 AM   #4
I never blow the piece off, that just creates lots of dust in the air, which will then settle on your project. Suck it off with a shop vac(HEPA is best) with a brush attachment. Depending on the wood, I will wipe with paint thinner and/or alcohol, then a tack rag.
Old 03-15-2012, 07:57 AM   #5
clean work space, vacuum, lacquer thinner, tack cloth.
That's just my opinion. But it's free, so take it for what it's worth to you.
1910NE is offline   Reply With Quote
Old 03-15-2012, 08:32 AM   #6
Rewards Points: 22
Same here. As long as I can move it outside, I like to blow it off with compressed air, but after that, lacquer thinner followed by a tack rag.
Old 03-15-2012, 04:36 PM   #7
Too Short? Cut it Again!
As mentioned, before you start on the piece, if you plan to refinish it where you sanded, vacuum the space thoroughly first or all your work will be for not. I like to wait a few hours or even overnite after vacuuming the space and refinishing project before starting to wipe and tack cloth the piece so any dust that did make it airborne will have settled on the surfaces.
One challenge you will face working with laquer thinner, etc. and your finishing products is providing yourself with adequate ventilation--especially in a small space. You cannot turn on a fan or open a window or you will have dust embedded in your finish coats and will only be able to sand and polish some of it out. You might want to invest in an aspirator and appropriate cartridges. They are not particular expensive and will save you a few brain cells.
Old 03-16-2012, 12:17 PM   #8
Rewards Points: 682
Thanks for the info.
After using a tack cloth a bit of stickiness is left on the wood. Is this an issue?
Old 03-16-2012, 03:37 PM   #9
Tack cloth should not have left anything behind. Perhaps the solvent you used before it had not fully evaporated and pulled something from the tack cloth. Repeat the steps leaving adequate time for the thinner or whatever to disappear and you should be fine.
Of course if it was sticky before the tack cloth the solvent may have loosened some remaining traces of the finish you took off and that were not visible anymore.
Old 03-18-2012, 07:44 AM   #10
Remodeling Contractor
When I took my class for certification of cabinet and furniture finishing from Mohawk we were told never to use a tack cloth. The piece is blown off only. but finishing is done is a spray both, so dust is never an issue.
Old 03-18-2012, 09:38 AM   #11
In a little over my head
Rewards Points: 706
I start with the brush attachment on my shop vac, then a tack cloth. Lately, I've been using a reusable/washable microfiber tack cloth and have been pleased with it.
ratherbefishing is offline   Reply With Quote
surface idea for basement floor Red Squirrel Building & Construction 1 02-06-2011 11:42 PM
Is a door slab still paintable if the surface is dirty? darsunt Building & Construction 4 12-19-2010 06:26 AM
Preparing Surface for Seeding pumpkinpatch Landscaping & Lawn Care 9 09-07-2010 04:15 PM
Concrete Dust on Prefinished Hardie Todd1 Building & Construction 1 01-06-2008 05:13 PM
IAQ and flooring. Briefly. Benhamcarpetguy Flooring 12 03-24-2005 09:53 PM
