Best Way To Case... - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-18-2012, 02:08 PM   #1
Rewards Points: 36
Best way to case...
this window. Ok, I couldn't upload due to file size... It currently has a sill that justs out and one piece of casing underneath cut back at maybe a 22 1/2 degree angle. kind of old school. How would I case this out completely? I was thinking just cut the casing for the sides square at the sill, maybe a slight notch on the inside edge for the sill. Or do I mitre all the way around and notch for the sill? Sorry it's vague, cant figure out to get my pic down to 100 kb or less.
tompatrick is offline   Reply With Quote
Old 03-18-2012, 02:32 PM   #2
Rewards Points: 36
Try tomptat03 on flickr, I'm new at this so I don't know how to post the link yet...
Old 03-18-2012, 05:48 PM   #3
Rewards Points: 13,296
Without a picture it's hard to help.
Old 03-19-2012, 01:40 PM   #4
Rewards Points: 36
Window pics
Hope this is the ticket. http://www.flickr.com/photos/78094035@N02/6847543826/
I'm thinking replace the bottom casing, run it past the sill 2 1/2" on each side. Run the side pieces down cut square on bottom (notched around sill, and mitered on top? Thx in advance for any suggestions. Tom
Old 03-19-2012, 02:40 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 192
If you plan to leave the stool like it is, just cut the trim like you are going to picture frame, notch out for the stool and install the trim.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 03-19-2012, 07:27 PM   #6
Rewards Points: 512
if you want it all trimmed out with your casing on 45s i'd pull off the sill and measure from the window to the outside of the drywall. cut and install build outs around the window then put your casing up around that.
princelake is offline   Reply With Quote
Old 03-19-2012, 11:08 PM   #7
Rewards Points: 77
You could try using rosettes on the corners and then cut in the vertical pieces of trim to take into account the little bit of overhang on the sill. I did that at a previous house but the sill extended past the trim so didn't quite have the same issue. Here's a (blurry) pic of it, but you get the idea.
dengle is offline   Reply With Quote
Old 03-20-2012, 01:31 PM   #8
Rewards Points: 36
Thank you all very much. I'll post pics when I'm done (if I can figure out how to get them uploaded). Now that i'm in trim mode, I was thinking about installing crown around my cabinets, but there isn't much nailing room between the top of the doors and the top of the boxes themselves. I've heard that it might be necessary to install nailing blocks for the crown. anyone know of an easy and clean way to do this?
1988 Case Model 688 Excavator old guy Landscaping & Lawn Care 9 05-21-2012 05:30 AM
Skill saw case rsteve12 General DIY Discussions 14 11-02-2011 06:37 PM
Entry Stair Case ralphfravel Carpentry 1 11-04-2009 08:03 PM
