Best Type Of Material For Shelving - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-01-2013, 10:56 PM   #1
Rewards Points: 666
Best type of material for shelving
I am building garage shelving that is going to be suspended. I am guessing that it will hold up to 100pds. What suggestions do you all have as to the type of material that I can use for the shelves? I don't need the material to be pretty. I am looking for something that is sturdy yet cost effective. What do you think?
kennykenny is offline   Reply With Quote
Old 07-02-2013, 06:37 AM   #2
Rewards Points: 13,300
Why does it need to be suspended?
A few 2 X 4's and some plywood will work.
http://www.bing.com/images/search?q=...ving&FORM=IGRE
Old 07-02-2013, 07:44 AM   #3
Rewards Points: 666
Due to space. Maximizing my space. Thanks.
Old 07-02-2013, 04:17 PM   #4
AHH, SPANS!!!
Rewards Points: 1,166
advantech 3/4" plywood for the shelf and 2x4 for the frame...
hand drive is offline   Reply With Quote
Old 07-02-2013, 04:24 PM   #5
bbo
you'll have to look into what your ceiling will support weight wise if you suspend it. I would suspect even doing some type of cantilever off the wall would let you raise the weight limit for sure.
bbo is offline   Reply With Quote
Old 07-03-2013, 10:03 PM   #6
Rewards Points: 666
I was just wanting input on suggestions on about different types of materials that might be used in place of plywood(i.e MDF or other types of material etc.) that might be just as strong and sturdy and might be more cost effective. Thanks!
Old 07-03-2013, 11:34 PM   #7
MarginallyQualified
Rewards Points: 2,464
What do you want to store?
What material(s) do you have access to?
I've seen pieces of unistrut suspended in sequence to hold boards.
Similar could be done with black or galv pipe.
hth
Old 07-04-2013, 01:59 AM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 1,162
For best all around performance and value...forget OSB or MDF....depending on support and span...1/2", 5/8" or 3/4" is your best material.
I've used Melamine for shelves in my garage....but....I attached a strip of SS to both the front and back edges of the material to keep it stiff
Old 07-04-2013, 07:20 AM   #9
Rewards Points: 274
Basically always try to select the best type of material. Don't compromise on quality.
alexjoe is offline   Reply With Quote
Old 07-04-2013, 07:44 AM   #10
PoleCat's Avatar
Rewards Points: 1,646
Particle board and MDF will eventually sag under their own weight let alone any additional load. I would use 1X as a first choice or 1/2" OSB set into a 2X2 frame.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Circuit breaker Type Q vs QP orange Electrical 6 12-15-2010 04:35 PM
framing material estimate maydoug Building & Construction 38 06-12-2009 02:32 PM
Gasket Material Chetter HVAC 6 01-31-2009 08:53 PM
Type WL Copper Pipe bathroom slave Plumbing 1 01-26-2009 01:30 AM
