Best Type Of Interior Door For Sound Dampening - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-12-2011, 07:59 PM   #1
best type of interior door for sound dampening
i will be changing my doors, to help with keep things quiet would i be be better off with a solid pine door or the solid core type doors thanks
bbillcee is offline   Reply With Quote
Old 01-13-2011, 12:43 PM   #2
I've seen a few sound reduction interior doors from JELD-WEN. Maybe something with their ProCore quiet technology would work well. Someone like Acoustical Solutions might have a door for your application as well.
TomB is offline   Reply With Quote
Old 01-13-2011, 12:47 PM   #3
Experienced
Jackofall1's Avatar
The heavier the door the better.
Old 01-13-2011, 02:42 PM   #4
A door a day is all I ask
TheDoorGuy's Avatar
When you say solid pine, are you talking about a wood frame and panel style door?
If so, the solid core door will be better for sound control than the wood doors. They
are thicker at the thinnest points and more dense to boot. 1 3/4" sc doors will help a
bit more than 1 3/8" sc doors.
Cut them as close to the floor covering as you can. Hopefully you are using carpet
because it absorbs sound as opposed to vinyl and wood which reflect or bounce sound.
Make sure that your door stop is close to the door all the way around...Not touching on
the hinge side though because it will bind after paint. In extreme cases I have used
the kerf style (qlon) weatherstrip to close up all of the gaps around doors. A bit unusual
for interior doors but quite effective.
Richard The Door Guy
www.thedoorguy.com
TheDoorGuy is offline   Reply With Quote
Old 01-13-2011, 04:38 PM   #5
This is so true. The last house I lived in had hard wood floors throughout and it was ridiculously loud if we were entertaining in one room and the tv was on in another, etc. Aside from that I think carpet is warmer and more comfortable.
Old 01-13-2011, 04:48 PM   #6
Is it ALL the interior doors in your house, or just a couple in particular? I'm thinking that a solid core door with weatherstripping and a self raising door sweep would help even more in an extreme case
mrgins is offline   Reply With Quote
Old 01-14-2011, 02:39 PM   #7
solid core interior door. The best thing to absorb sound is mass. Code usually stipulates a 1" gap under the door for air circulation
masterofall is offline   Reply With Quote
Old 01-14-2011, 04:37 PM   #8
1"? Where are you? That's quite a gap
Old 01-15-2011, 12:39 PM   #9
Masonite makes a door called "Safe and Sound"
It's fire resistant and sound resistant. I have one on my practice room and my wife tells me it makes a huge difference. If you leave a big gap under it though, the sound will go right under.
pyper is offline   Reply With Quote
Circuit breaker Type Q vs QP orange Electrical 6 12-15-2010 04:35 PM
screw type bulbs. mpj111 Electrical 5 01-27-2009 04:27 PM
Type WL Copper Pipe bathroom slave Plumbing 1 01-26-2009 01:30 AM
Need help with Type T and TL fuses? Fotoguy Electrical 6 03-04-2008 02:08 PM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 08:53 PM
