Best Material For Laminating Formica - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-30-2012, 08:41 AM   #1
Best material for laminating formica
Am building a bar and plan on laminating with formica. I need a material that is strong enough to span a 28" wide by 60"long by 1.5" thick section without sagging, but is smooth enough to accept the cement and form a nice bond with the laminate without coming loose down the road. I am not sure mdf or particle board will do the job without sagging over time and not sure if osb is smooth enough. I am leaning towards a nice smooth plywood but it is a lot more expensive. Any thoughts?
toobhed is offline   Reply With Quote
Old 03-30-2012, 09:02 AM   #2
Haverhill Trade 1965
You could try laminating 3 layers of 1/2" plywood. Use a spreadable adhesive so you get complete adhesion. Use a lot of weights, again for even distribution. If it is going to free span most of the distance you could even force a slight crown into it. Put shims under it with thicker ones in the center gradually using thinner ones toward the ends. You only have to use a good piece for the top layer, AB or lumber core, that should be cheaper than one thick sheet.
Duckweather is offline   Reply With Quote
Old 03-30-2012, 11:30 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 202
2 sheets of 3/4" BC plywood would work well, I sure wouldn't use OSB board.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following 2 Users Say Thank You to BigJim For This Useful Post:
kwikfishron (03-30-2012), woodworkbykirk (03-31-2012)
Old 03-30-2012, 12:35 PM   #4
high density particle board with 1x3 pine, or maybe hardwood, glued/screwed across the 28" part to give it rigidity
mrgins is offline   Reply With Quote
Old 03-30-2012, 08:02 PM   #5
kwikfishron's Avatar
Rewards Points: 202
I always face my laminate counters with Oak (or another Hardwood), whether it's exposed or not.
kwikfishron is online now   Reply With Quote
Old 03-30-2012, 09:18 PM   #6
Rewards Points: 512
they 1 1/8" particle board then add some 3/8" to get the thickness you want. the sheets of particle board that were 1 1/8" thick were 5x12' some heavy stuff!
princelake is offline   Reply With Quote
Old 03-31-2012, 11:10 AM   #7
Lot's of good info, thanks everyone. I need to laminate the bottom as well since its is very exposed so i think i will go with three layers of 1/2" bc; i can get it done with one 4x8 sheet so that should help me keep it simple.
Thanks again!
Replacing underlayment in entire house...what material to use? Dave321 Flooring 23 12-23-2011 03:38 PM
Gap-filling material for r.r. tie sidewalk Hi Country Home Building & Construction 1 05-28-2011 09:58 PM
Water Fall - Black bonding material cprao Landscaping & Lawn Care 3 04-23-2011 04:06 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 08:41 PM
