Bearing Wall - Jack Studs - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-29-2011, 07:45 AM   #1
Hello,
I removed a load bearing wall and installed a header made from 2 2 x 10's. The new opening is 8 foot wide. This is on the fisrt floor of my 2 story home. I believe the new header is supporting part of the roof load.
I was wondering if there is a "rule of thumb" as to how many jack studs are needed on each side to support the header.
I currently have 3 2x4's on each side supporting the header and I would like to remove as many of them as possible.
Is one 2x4 jack stud enough on each side?
Thanks!
Tomperro is offline   Reply With Quote
Old 04-29-2011, 11:02 AM   #2
Registered User
Rewards Points: 5,516
NO! Check table R502.5(2) as 2-2x10 support 1 floor will only span 3'10" - 4'11" w. 2-3 jacks each side; http://publicecodes.citation.com/ico...002_par021.htm
Gary
Old 04-29-2011, 09:00 PM   #3
Little confused on how to read those charts.
The bearning wall is on the first floor and right under where the second floor joists overlapped or extended. For example, there is a joist running from the fron tof the house to where the wall was, this joist ends about 3 inches past the bearing wall and another joist continues to the back of the house and is nailed to the side of the original joist. Make sense?
Above is a bedroom and above the bedroom is the attic. The roof is a truss roof where the peak is parallel to the bearing wall.
Are the 2 2x10's enough?
If it is enough, how many jack studs for the 8 foot span?
If not enough, can you tell me what I need, based off those charts?
Thanks.
Old 04-29-2011, 09:16 PM   #4
Registered User
The table shows; 20' building width span (running with the trusses) = 2-2x12's = 8'1" span #2 grade lumber.
28' building width = 2-2x12's = NO (requires 3-2x12 + 8'10" #2 lumber)
Two jacks each side, solid blocking in floor below to beam or pier. You should get a permit for this, for the paper trail for your Homeowners Insurance carrier and when you go to sell the house.
Gary
Old 04-29-2011, 09:27 PM   #5
Is it too late to get a permit once the project is started?
Also, there is a header installed already, by the builder when the house was already built that supports a span of 12 feet, it is 3 2x12's, accoring to the chart, is this not correct?
T
Old 04-29-2011, 09:41 PM   #6
Rewards Points: 1,016
I would get a permit even though you have started. Go to your building department and speak with them. You will not be the first to have done this.
If I were buying your house and see the modifications I would be asking the permit questions. Sure is easy and better to answer yes in the future rather than having to dance or deal with it way after the fact.
____________
Vince
Old 04-29-2011, 09:46 PM   #7
Framing Contractor
Gary
Gary,
That's not the main reason why he should get a permit. He should be told why he needs permits especially for what he's doing.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 04-30-2011, 11:49 PM   #8
Registered User
"lso, there is a header installed already, by the builder when the house was already built that supports a span of 12 feet, it is 3 2x12's, accoring to the chart, is this not correct?" -------- No, it is over-spanned for the loads.
I say again, get a permit----- because you are dealing with potentially thousands of pounds unsafely carried above you.
You already removed the wall added a header and jacks--- now you want to remove some jacks to make a weak header even weaker........ Hence my first reason to get a permit might have prompted you more than loads involved....
If Joe C. (previous post) makes it unanimous, will you get a permit?
Gary
Old 05-01-2011, 01:23 AM   #9
Sure hope you have your point loads being carried down, that's why we get permits
chrisBC is offline   Reply With Quote
Old 05-01-2011, 02:18 PM   #10
Tizzer's Avatar
Rewards Points: 460
In case you don't know what Chris said about point loads are, the weight carried by whatever jacks/header you use, needs to be carried down to the foundation.
The floor alone cannot carry this weight.
Tizzer is offline   Reply With Quote
Old 05-01-2011, 02:45 PM   #11
so basically the header I have is not correct
Replacing load bearing wall KarlJay Building & Construction 4 12-27-2013 03:44 PM
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 12:17 PM
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 04:33 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
Is this Load Bearing Wall remodel-virgin Building & Construction 16 05-11-2009 04:25 PM
