#1 |
Beam to floor joist connection?
I attached a picture to easily explain. How do I attach a beam to the floor joist securely. Header that the beam will carry spans over 4 joist. Header will carry about 1/4 of the load up top(another floor plus osb roof and asphalt shingles) Cannot connect to bottom floor of basement because it would block a basement window. Thanks
| The Following User Says Thank You to daltinator For This Useful Post: | rubberhead (07-14-2012) |
#2 |
Retired Cabinetmaker
I would check your local building codes.
My understanding is that the total weight has to be transferred to the foundation. If a window does not allow direct vertical transfer, then a header needs to be placed over the window and supported by a post or column either side and attached mechanically to the foundation with all the joints be strapped Mike.
"I'm not as green as I am cabbage looking" |
| Tags |
beam, connection, floor, header, joist ![]() |
| Display Modes | |
| Need help with bad beam | LVDIY | Building & Construction | 55 | 07-12-2012 07:31 PM |
| Adding posts and beam to floor for aquarium | Vincer | Building & Construction | 4 | 03-23-2011 03:47 PM |
| Main structural support beam HELP!!! | Daniel048225 | Building & Construction | 34 | 02-17-2011 12:35 AM |
| Basement Beam and Columns..... | shamrock33 | Building & Construction | 1 | 03-19-2008 06:03 PM |
| Hanging a beam/rafter from a beam | snmhanson | Building & Construction | 4 | 01-11-2007 11:37 PM |
